Bottom line: thermal paste is not a very good heat conductor.
Yes, absolutely. It's just meant to fill up the tiny air gaps between the heatsink and component due to surfaces not being perfectly flat and smooth. That's all. Ideally, there should be a thin layer barely thicker than the max height of said gaps. That's very little.
If we look at typical thermal pastes, they are basically a suspension of ceramic and metal (oxide) particles in sillycone or sillycone oil.
Their thermal surface properties are much better than their bulk properties. In a thin enough layer, basically just filling the microscopic pockets, they're stable and have very nice thermal conductivity.
Compare to how surfactants work, say soap on top of water. (They form a single-molecule thick layer at the surface, be that surface to air or to a dirt particle.)
As a macroscopic blob or a layer thick enough to no longer be "surface only", thermal paste thermal properties differ, because surface and bulk can have wildly different properties. Typically, the suspended particles start to clump, and the oil leak out or evaporate. The clumping does not really happen in a 2D layer.
If we get down to the molecular scale, surface properties and bulk properties can be
extremely different. A good example of this, one I'm well familiar with (from simulation and modeling side, not from using in practical applications), is stainless steel and other ferrochrome alloys (iron + chrome). Even at room temperature, the chromium atoms slowly diffuse closer to the surface. When the average chromium content is between 13% and 25%, the chromium density is much higher near the surface, forming clusters and "dendrites" towards the bulk. (These were first imaged after the turn of the millenium, too; the surface structure just forms too easily in normal conditions.) This is what makes these alloys resistant to oxidization. This surface layer is hundreds of nanometers thick, too, and just won't show up in simulations unless you have millions of atoms, so you can see the difference in bulk and surface.
And, as we all know, nanoparticles are extremely useful in e.g. LEDs, and are nothing but clusters of atoms (typically metals), with the cluster
size carefully controlled. There is no bulk at all, and the surface properties and the size of the cluster determines its properties, especially phonon spectra, including the visible color (visible photon absorption and emission spectrum due to surface phonons limited to specific modes due to particle size, the good ol' quantum stuff).
Rubbery potting compounds and silicones do not dry out even when used in bulk, but even there, if you cut a blob open and poke it with a sharp pokey thing, you can observe the difference in the surface and bulk properties (until the bulk also oxidizes et cetera, and the sliced part becomes a new "surface"; this was long the reason actual cross-section images at the atomic scale of stainless steel and ferrochrome alloys were so hard to obtain). Even if a decade old, the innards are more "liquidy" than the surface.
