Author Topic: Where can I buy a proper workbench (USA)?  (Read 2507 times)
Offline Dave92F1Topic starter
    • Nerdfever
« on: February 27, 2025, 03:22:06 am »
I'm old and I've become picky.
Where can I get an old style electronics workbench, the sort that used to be bog-standard stuff at Digital Equipment and IBM in the 80s? I mean the kind with:
* Sturdy steel legs
* Instrument shelf on a riser with electrical outlets at the front (and NO LIP at the back of the shelf)
* 72" wide x 36" deep x 30" tall
* 2 or 3 drawers on one side
ESD top isn't important - I buy ESD mats and cut them to size.
I'm in south Texas USA. I'll buy new if I have to, but I can't find anybody who makes these things anymore.
Closest I can find is stuff I've put in the photos - either no outlets, or a lip at the back of the shelf (long instruments won't fit), or no riser or no shelves.
Suggestions?
Offline RJSV
Re: Where can I buy a proper workbench (USA)?
« Reply #1 on: February 27, 2025, 04:00:17 am »
Since it's easy to do, (and I don't do much on-line my route would be straight to
O'Rielly's Auto !
   You could probably check stock on-line,  but decent chance they at least sell some kind of 'portable,  knock apart or folding 'bench'.
Could then customize,  as you would ready have a sturdy structure,  (even though crappy plastic, at first glance.
Offline octillion
« Reply #2 on: February 27, 2025, 04:24:36 am »
https://www.iacindustries.com/
I bought a couple custom benches from them a few years ago. Good quality and sturdy. I ended up making my own electrical panels and lighting as those options were overpriced in my opinion.
I've also made benches from parts at McMaster-Carr, they have even heavier duty options if needed.
The following users thanked this post: Smokey, RJSV
Offline radar_macgyver
« Reply #3 on: February 27, 2025, 05:40:09 am »
My current workbench that meets almost all your criteria except for the lip at the rear is from Global Industrial. I have the ESD top, but they have other options. I got the standard duty version, and specified a riser that includes a power strip. I also got a drawer and a 'lower shelf' which is a good foot rest. It seems like the rear lip (the backstop) is optional and can be removed.
Offline mawyatt
« Reply #4 on: February 27, 2025, 07:24:47 pm »
Harbor Freight has the one in the middle, we have one in the garage. Sturdy and nice natural wood surface, really good for the $. Our electronics lab benches are made up from the IKEA stuff (desk type), also really good for the $. Not as sturdy as a proper work bench for heavy mechanical work, but good enough for our electronics needs!!
Best
~Wyatt Labs by Mike~
    • Nerdfever
« Reply #5 on: February 27, 2025, 08:12:59 pm »
Can you post a link? When I go on HF's web page, below is all I see for "large workbenches".
None of those is 72" wide or even close.
    • Nerdfever
« Reply #6 on: February 27, 2025, 08:17:47 pm »
Are you sure? If I can remove it (without sawing it off), I'd buy that. I have a bench that looks similar and the lip on that one is definitely not removable.
It's too big to order and then send it back if it's no good.
Offline mawyatt
« Reply #7 on: February 27, 2025, 08:51:22 pm »
(Attachment Link)
It's a Husky like this one from Home Depot. We got it from Harbor Freight tho long ago.
Best,
Online jpanhalt
« Reply #8 on: February 27, 2025, 10:28:36 pm »
You've gotten a lot of good ideas, but my two favorite workbenches are made from salvaged bowling alley lanes:
https://cleveland.craigslist.org/mad/d/bowling-alley-wood-multiple-sizes-types/7824520923.html
Shipping is prohibitive.  They are heavy.  If there's been a bowling alley fire or one going out of business nearby, that's the place to go.  Get two, if you have the space.  Then, I bought steel legs with a cross brace for them.  That said, for my electronics, I just use a typical office desk with a modesty brace/panel across the back.  If you want a drawer, nice metal drawers can be had reasonably and screwed to the bottom of the top.
Offline thm_w
  • Non-expert
« Reply #9 on: February 28, 2025, 12:14:31 am »
If the lip is an issue, just put a piece of wood or some other riser on the top shelf.
If no outets is an issue, just buy an outlet bar and screw into place.
Not that hard.
Or pay out the ass for something like this
https://www.homedepot.com/p/ProLine-60-in-W-x-30-in-D-Heavy-Duty-Adjustable-Height-Workbench-with-Laminate-Top-BIB2/304242363
Offline EPAIII
« Reply #10 on: February 28, 2025, 01:22:57 pm »
You can look first at McMaster. They have all the parts and you just order the ones you want. They do have the 72" x 36" size you mentioned. As far as the backstop on the upper shelf, just turn it upside down. But ask if that is going to work before you buy.
https://www.mcmaster.com/products/workbenches/workbenches-2~/workbenches-6/
There are others if you don't find what you like there. Grainger will save you the shipping cost if you can pick it up at a local store. Again you order the pieces you want and assemble as you like. And just flip that upper shelf over.
https://www.grainger.com/category/material-handling/storage-workspace/workbenches-shop-furniture/open-base-workbenches/stationary-open-base-workbenches-with-storage?redirect=workbench&searchRedirect=workbench&tier=Tier+&categoryIndex=2
And Global:
https://www.globalindustrial.com/c/work-benches/workbenches_worktables?q=workbench
And MSC:
https://www.mscdirect.com/browse/tn?navid=2105590&searchterm=workbench
And many, many others.
If you want that "bog-standard stuff", just where do you think those companies you mentioned and all the other companies, beyond number purchased it? NOT at HF or Sears or Radio Shack or other retailers. They went to industrial suppliers. More expensive? You betcha! Two, four, even eight or ten times as much. But that's what they charged then as well as now.
I also worked at those "bog-standard" benches all my career, mostly at smaller companies you never heard of. But that's where they bought them and they paid those industrial prices.
But personally, in my own shop I'm cheap. I mostly MAKE MY OWN. It is not only less expensive than the industrial stuff, but also less than the consumer benches at HF, etc. And frankly I can do the same work at any kind of bench. It ain't the bench: it's the man seated at the bench.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Offline EPAIII
« Reply #11 on: February 28, 2025, 01:34:31 pm »
Adding an outlet strip! Bingo! That's what I do, often more than one. I have one bench with two, heavy duty, six outlet strips attached to the front edge. I bought them at a local home supply store (Lowe's or Home Depot or similar) and they cost about half what a professional strip would cost. Edit: That bench actually has three of those outlet strips; two in front and one on the end of the rear back-splash. I have work stations both in the front and on one end where the rear strip supplies the power.
Other benches that I have feature similar strips at the rear. I never run out of outlets. Of course they could be at the back or on the shelf or on the legs or whatever suits your fancy.
I also like adding the under the cabinets style lights that are sold everywhere. Mounted under a shelf they give me a lot of light right where I need it. I have two of them at some benches.
Another edit: While I am editing this response I will say this about drawers. Many benches feature a vertical stack of drawers at one end. This is OK and two of my benches are like that, but I have constructed my most used bench with four drawers mounted side by side, just under the top. Again, being cheap I used some drawers that were salvaged when my kitchen was remodeled. I added ball bearing tracks and repainted them. They allow my legs to be under the bench along a much longer space. It isn't pretty, but I really like how it worked out. IMHO, that is a lot better than taking up all the knee space at one end.
Not that hard.
« Last Edit: February 28, 2025, 01:53:06 pm by EPAIII »
Paul A.  -   SE Texas
« Reply #12 on: February 28, 2025, 08:47:23 pm »
I had missed that you were referring to the lip on the shelf rather than the benchtop. The shelf lip is on the top piece of sheet metal that is bent upwards. You could cut it off or bend it flat, but that would make the top structurally weak (the bend is what gives it cross sectional area to avoid bending in the Z axis). If the idea is to allow deeper instruments to dangle off the back, a piece of plywood or MDF to raise the whole instrument up to the level of the lip would do the trick. I also have the Proline bench linked to by @thm_w in my garage (I bought it off Craigslist for ~$400); the Global Industries bench feels sturdier to me.
The only 'deep' instrument I have is an R&S ZVC VNA, and that would likely collapse the riser due to its weight :)
Offline Stray Electron
« Reply #13 on: February 28, 2025, 08:58:23 pm »
   This place. https://www.lislecorp.com/ All of the really good workbenches that I've seen in places like IBM and inside of US Gov contractors are almost always this brand and they are built like the proverbial Brick****house.  But the prices are positively eye-watering!  But they do show up on Ebay occasionally and since they're so heavy people don't want to ship them so if they're local or if you're willing to drive to pick up up in person you can usually negotiate a very good deal.  You can probably also buy them through Grainger and the other Industrial equipment suppliers.
Offline Arts
« Reply #14 on: March 01, 2025, 03:29:12 am »
I swear by the old-school Lista work benches or work stations. Nobody but companies can afford to buy them new, but sometimes they can be found at auctions or on  local sell-sites.
Offline neverendingstudent
    • YouTube Channel
« Reply #15 on: March 05, 2025, 04:51:06 am »
Craigslist / Facebook Marketplace / local auction houses.
If you buy new, expect to sell a kidney.
You can get them SUPER cheap (in comparison) on the secondary market, you just have to do a bit of hunting around your local options.
Online jonpaul
    • IEEE Spectrum
« Reply #16 on: March 06, 2025, 12:42:33 am »
OP: At auction in 1980s, we Bought several of the last bench in your initial  post.
Indeed the upper shelf was useless, short and risky.
We gave them to a fine carpenter, Elliot removed the upper shelf and built fine formica shelf, 18" deep, with backstop and 5 deg tilt.
Even heavy rackmount instruments are secured.
We added outletstrips under the shelf and above the main surfece.
The 4' depth is especially useful.
Your comments appreciated,
Enjoy,
Jon
The Internet Dinosaur..
passionate about analog electronics since 1950s
