I've got some 1W green LEDs, mounted on standard 20mm diameter "star" aluminum PCB carriers. These LEDs have an 8mm diameter white package with a transparent plastic dome-shaped lens on top, about 5mm in diameter.
I am using some of these as point sources for an autocollimator, and would like to know, where is the optical center of that point source located? Since the lens is collimating the light, I believe that this optical center will lie on the axis of the LED, but slightly BEHIND the physical chip. Can someone confirm or deny? Is there any documentation (from any manufacturer) which indicates where this optical center is located?
[Mods: if this is the wrong forum, please move to the correct location.]
