Comments are welcome, just consider this is a hobby project.
Why is +9V an air wire? I think it should chain from the 12V regulator since that's what it actually does. You can take a tap off that connection for global 9V, but as it is your eye misses where it's connected because you don't expect to look right next to it - it would surely have a wire if it were that close!
The 12V I an not sure about. I think if you can't attach the regulator input to the connector then they should be on separate sheets: a PSU sheet and perhaps a connections sheet (or, better, shove it on the overview sheet like the two coaxs). But if you put the connector on the left (the SDA/SCL are inputs, after all) then a wire from +12V on the connector to the regulator surely wouldn't be that messy.
C508-C510 should be on a single power bus rather than separate air wires for each. If they are meant to be close to U503/5/7 then either put them there or have all such caps on the power bus (C501-C503). And since it's a preview and not a modded production schematic, the caps should be annotated in a consistent way (I prefer top to bottom, left to right, but consistency is key).
(Non-ICs are annotated that way, whereas ICs are annotated top to bottom, left to right (or whatever the preference is) on the PCB. Reason being on a decently complex board board you'll spend forever trying to find R78 on the PCB so you make it easy to find on the schematic. ICs are pretty obvious, on the PCB by may be spread over more than one sheet of schematic (or in several parts on the same sheet). So knowing from the schematic R78 is on a U15 pin, you know whereabouts on the PCB it is likely to be. Admittedly, the way ICs are annotated isn't that important nowadays - it mainly came about due to the tons of 74 series DIL chips in neat rows.)
The colour scheme... I found Fout hard to look at, and because it's so different from other wires my eye keeps thinking it's part of a border or box or something. I think this is a personal thing and colours are not bad per se, just that particular one. Of course, I could print it in mono if necessary, so this is just a comment without an aye or nay component
Thanks for your comments - answering only now since I'm on a skiing week with almost no internet.
I'll start from the last one: the color scheme is the Kicad one, and not used to convey information, with possibly the exception of the blue 50 ohm nets (but there are flags signalling that).
Printing in B/W would not change readability, I should have thought of it - given the amount of discussion this has generated.
As for numbering: yes, it's a bit messy, I have manually assigned them in some cases but mostly relied on the automatic renumbering.
As the different sheets correspond to different areas on the PCB, the numbering ranges are at least consistent.
Decoupling caps on the clock buffers: noted, pure laziness on my side.
Regulators and I/O comments: I had tried in a previous version to connect them all, but did not really like the result. The connector is actually input (SDA/SCL) and output (Audio, in fact a 24 KHz IF).
All in all, not too bad I'd say, thanks for the detail analysis.
