Author Topic: Where to buy V/I LED panel meter with high-side Isense and +/- current.  (Read 447 times)
Offline PsiTopic starter
So I'm looking for a voltage and current LED panel meter that will show
Specs
- DC Voltage = 0-16V with 0.1V or better resolution
- DC Current = +/- 6A with 0.1A or better resolution  (must be able to read negative) -
- Must be high-side current sense (hall effect is fine)
- Max $20 each, ideally $10-$15.  Doesn't need to be super high quality for this intended use.
Optional / Nice to have
- Bonus points if it shows Watts too, but that isn't needed.
- Also bonus points if the unit is properly isolated on the power or on the I sense side to avoid shorts when trying to use multiple units to measure different areas of the same circuit.
Any recommendations or links?
Thanks for your help
« Last Edit: September 20, 2020, 08:13:18 am by Psi »
Re: Where to buy V/I LED panel meter with high-side Isense and +/- current.
« Reply #1 on: September 20, 2020, 08:56:25 pm »
 Nevermind, i needed to alter my search terms abit on aliexpress for them to show up.
I have a few options now.
