Please help.
I'm not having much luck on google, I need a brushless motor (that I can get here in Australia) that goes up to 3000rpm to drive an aluminium centrifugal fan blade (118mm diameter, 30mm height, 100g weight) the blade has an opening for a 6mm shaft.
I want to control the speed with an MCU, the motor input voltage is not important, I can provide it any voltage.
Budget is around $50.
Thanks for looking.
Richard
