Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
Where to get these pots
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Where to get these pots (Read 822 times)
Yamin
Frequent Contributor
Country:
on:
November 23, 2019, 03:10:31 pm »
Hi guys,
I'am looking for these pots (photos attached). I need the ones with the lead bent 90 degrees. I'am looking for a 500K log pot and 100K linear pot. Could you recommend a brand or an online shop which carries them.
Thanks
Logged
mariush
Super Contributor
Country:
Re: Where to get these pots
Reply #1 on:
November 23, 2019, 03:47:33 pm »
Plenty of similar potentiometers.
Measure the diameter of the actuator and its length ... everything else is less important (you can add some plastic /rubber/ whatever spacer between the pot and the pcb if it's thinner.
Silkscreen says they're 100k ohm, logarithmic, so that reduces the search as well.
You can probably bend the leads of the following and cut/shape the ends with some pliers to go through hole:
https://www.digikey.com/product-detail/en/tt-electronics-bi/P160KNP-0EC15A100K/987-1717-ND/5957461
https://www.digikey.com/product-detail/en/bourns-inc/PDA241-SRT02-104A2/PDA241-SRT02-104A2-ND/3781557
https://www.digikey.com/product-detail/en/tt-electronics-bi/P231-FC20AR100K/987-1323-ND/2408900
Here's another example:
https://www.digikey.com/product-detail/en/bourns-inc/PDB12-H4251-103BF/PDB12-H4251-103BF-ND/3780660
edit: saw the second picture... there's 100k ohm linear and logarithmic and 500kohm log ...
Last Edit: November 23, 2019, 03:50:16 pm by mariush
Logged
Yamin
jesuscf
Country:
Reply #2 on:
November 24, 2019, 06:42:51 pm »
These ones look a lot like the ones in the picture, but they have short pins:
https://www.digikey.com/products/en?keywords=P160KN-0QC15B100K
https://www.digikey.com/products/en?keywords=P160KN-0QC15A500K
I think the ones you actually need with long pins, by looking at this datasheet
https://www.ttelectronics.com/TTElectronics/media/ProductFiles/Potentiometers/Datasheets/P160.pdf
are part numbers P160KN2-0QC15B100K (linear) and P160KN2-0QC15A500K (log). Sadly not stocked neither by DigiKey nor Mouser.
Since the ones you want to replace have a broken shaft, something that you can try is buying a mechanically compatible pot of a different resistance, disassemble them (not to hard to do) and swap the broken shafts with the new ones.
Correction: Mouser has stock of P160KN2-0QC15B100K
Last Edit: November 24, 2019, 06:58:29 pm by jesuscf
Logged
Homer: Yeah, but faster!
ZeTeX
Country:
When in doubt, add more flux.
Reply #3 on:
November 24, 2019, 07:51:52 pm »
I believe taydaelectronics carry those.
Logged
jesuscf
Country:
Reply #4 on:
November 24, 2019, 08:47:51 pm »
Quote from: ZeTeX on November 24, 2019, 07:51:52 pm
I think I found one:
https://www.taydaelectronics.com/potentiometer-variable-resistors/b-100k-ohm-linear-taper-potentiometer-with-pc-mount.html
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
