I have a basic understanding of whetting current for switches and relays, the minimum amount of current recommended to keep the switch "healthy" by burning off oxidation. Some switches are designed for large currents and may require amps of whetting current and supposedly will not work reliably feeding very low currents such as the input of a micro. Gold plated switches, on the other hand, typically only need mAs.
The details, however, are still a bit of a mystery to me. Many times the whetting current is given at a particular voltage, say 10mA at 5V. But... a closed switch is typically very low resistance, and the voltage drop across the switch will only be mV. So why would the rail voltage matter?
Also, does anyone have any sense for the time required for the wetting current? If I want to use a capacitor to surge current through the switch, for example,, how long is typically required to accomplish the required "cleaning"?
Any insight appreciated.
