It's a silly test.
I prefer silicon because it's cheaper, has higher gain and is more temperature stable. A modern solid state amplifier uses more than one gain stage with negative feedback, not a single common emitter amplifier so the test is rather pointless in this day and age. All things being equal, silicon will come out on top because the higher gain means more negative feedback and greater temperature stability, meaning the bias point will change less as the circuit heats up.
