Author Topic: Who knew you could measure UHF antenna's impedance with a DMM?  (Read 18466 times)
Offline grumpydoc
Re: Who knew you could measure UHF antenna's impedance with a DMM?
« Reply #25 on: February 21, 2013, 04:26:05 pm »
Surely you just plug the banana into the banana plug!
Offline mamalala
« Reply #26 on: February 21, 2013, 04:45:53 pm »
Nah, you plug the banana plug into the banana, of course. What you propose is akin to plug a wall into a wall-socket. :D
Greetings,
Chris
Offline zibadun
« Reply #27 on: February 21, 2013, 08:39:47 pm »
The author
"Laurie Brown has worked as a high school English teacher for the last several years and loves writing. She enjoys helping her students develop a love and appreciation for writing, reading, and literature. Laurie has a degree in education with a major in English. Currently she is a writer for eHow."
Yes, Laurie, the article is grammatically correct  |O
Offline c4757p
  • adieu
« Reply #28 on: February 21, 2013, 11:15:02 pm »
Like this? Seems somebody though it was a good idea...
Offline ivan747
« Reply #29 on: February 22, 2013, 12:13:12 am »
Is this compatible with plantains?
Online The Electrician
« Reply #30 on: February 22, 2013, 05:31:02 am »
And under the heading "What other people are reading", we find:
How to Measure an Antenna's Signal With a Multimeter
http://www.ehow.com/how_12130900_measure-antennas-signal-multimeter.html
where they use the ohms range on the Multimeter to "Measure an Antenna's Signal".!!!!
Offline PA4TIM
« Reply #31 on: February 22, 2013, 12:52:05 pm »
The topic title is not so far off, it is indeed possible to measure the impedance of an antenna or other network with a multimeter.  ;)
But you need 3 of them and RF detector probes, google for impedance measurement 3 Voltmeter methode, this is from the time before impedance bridges and impedance ( RF-IV) meters, vector voltmeters  and VNAs. ( if I remember well it can also be done with 3 current meters)
I never tried it, but it is still on the to do list. But there are more ( forgotten) ways to to IV impedance measurements, like using a double ballanced mixer and voltmeters.
Offline mcufreak
« Reply #32 on: February 23, 2013, 12:15:06 pm »
Ha ha ha what a topic !!! :o
and that comment from 'sacherjj' about measuring banana resistance is one solid piece of entertainment.   :-DD
may be I should start learning about how to use a DMM again ..  :P
