Author Topic: Who needs USB type C anyway?  (Read 1822 times)
Offline androidTopic starter
« on: April 20, 2016, 01:59:56 pm »
I've just had a play with some of these reversible USB cables (not type C) and I have to say they work a treat...considering that, on the face of it, they amount to putting a square peg into a round hole, I was quite surprised:
http://www.blitzwolf.com/BlitzWolf-2.1A-Reversible-Braided-Micro-USB-Cable-Double-Sided-USB-A-Male-to-Double-Sided-Micro-1m-p-46.html
A bit of mechanical engineering magic!
(hmmm...sounds like an ad, but I have no affiliation with the vendor, I assure you :))
Lecturer: "There is no language in which a double positive implies a negative."
Student:  "Yeah...right."
Offline botcrusher
Re: Who needs USB type C anyway?
« Reply #1 on: April 20, 2016, 02:03:01 pm »
I've thought about this before, not sure why they even bothered to make type C.
Offline XOIIO
« Reply #2 on: April 20, 2016, 02:41:11 pm »
Higher current capacity?
Offline ajb
« Reply #3 on: April 20, 2016, 04:37:23 pm »
Also USB3 features and throughput in a smaller form factor, suitable for tablets and phones.  Having the same connector on both ends also makes it easier for one connector to serve different roles--a single connector on a notebook can be used to charge the notebook from the wall, or to charge a phone from the notebook, or to connect peripherals all with the same USB C-C cable.
I got a Nexus 5X recently and personally I like the USB C connector a lot, and one bonus benefit for phones is that it's WAY easier to clean impacted pocket lint out of a C connector than a micro B.  The plastic tongue inside the micro B socket is so close to the inside of the metal shell that you can't really get any sort of implement in there when it gets fouled with dust and lint.  C has enough room to get a needle or somesuch in there when needed.
« Last Edit: April 20, 2016, 04:40:51 pm by ajb »
Offline wraper
  • Country: lv
« Reply #4 on: April 20, 2016, 04:49:23 pm »
I have a phone with USB type C connector, and it's very nice. Plug just slides in very easily. On the other hand, micro usb 3.0 is a piece of shit, looks like a dog with a fifth leg, also:
v
