Author Topic: Who sells this or similar LED panel indicator? - can't find anywhere  (Read 1645 times)
Offline CirclotronTopic starter
These high brightness red+green LED panel indicators were installed 7 years ago and after ~60,000 hours they are starting to get dull and need to be replaced. Can't find anywhere that sells them or something similar. element14, RS, Digikey all draw a blank. Plenty of other kinds but nothing remotely like these. Any ideas, preferably from a major seller in Australia? 12Volts DC. Approx 60mm x 90mm.
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: Who sells this or similar LED panel indicator? - can't find anywhere
« Reply #1 on: October 08, 2020, 04:44:20 am »
Why not just replace the LED's?
« Reply #2 on: October 08, 2020, 06:17:36 am »
The insides of the units are potted with epoxy.
Offline floobydust
« Reply #3 on: October 08, 2020, 08:05:58 pm »
The lens cover has text on it, I can't quite read it but surely the manufacturer's name  :-//
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
« Reply #4 on: October 08, 2020, 10:19:45 pm »
fug
Offline floobydust
« Reply #5 on: October 08, 2020, 10:56:42 pm »
After 60,000hrs I would just put in a new one. Every part is likely near end of life and if this is for safety it's EOL.
This style indicator all I see are automotive/marine versions. Otherwise it's signal (light) towers or "Andon Towers" with 360 degree viewability used i.e.
https://assets.omron.eu/downloads/brochure/en/v2/signal_towers_series_brochure_en.pdf
There are also red/green loading dock lights that are similar.
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #6 on: October 09, 2020, 09:12:06 am »
Agreed, I have seen quite similar looking LED assemblies on car-roof-mounted light bars, also fully potted. Green would be uncommon there though which might suggest marine.
Offline LaserSteve
« Reply #7 on: October 09, 2020, 02:17:51 pm »
Green is now used in the Northeast and Midwest States of the US on construction vehicles and plows/ salt trucks alternating with yellow or yellow and white  as warning lights.  As green Leds are far more monochromatic then the traditional cast Pyrex or Molded Plastic lens, this is being allowed now.    The first winter they were out, here in Ohio, this drastically reduced accidents with salt trucks being rear ended. In fact it got to the point that winter drivers started complaining about the relative brightness to the Governors office.  So they dialed them back in brightness.   I love them, the salt trucks and plows, a constant slow moving hazard in the winter, are now visible from miles away and you can plan your path accordingly.  The blink patterns are chosen so there is NO way to confuse them with traffic lights.
Works great in scotopic, mesoptic, as well as photopic vision conditions.  Works well enough that now the construction companies are getting them as well.
http://www.dot.state.oh.us/Services/Pages/New-Colored-Light-Combinations-on-Snow-Removal-Equipment.aspx
https://youtu.be/a7N7ubnf6UY
Green, Not just for Maritime and Aviation any more.
Steve
« Last Edit: October 09, 2020, 02:25:31 pm by LaserSteve »
"When in doubt, check the Byte order of the Communications Protocol, By Hand, On an Oscilloscope"
Quote from a co-inventor of the PLC, whom i had the honor of working with recently.
Offline themadhippy
« Reply #8 on: October 09, 2020, 02:22:22 pm »
In the uk green flashing lights on a vehicle used to mean emergency doctor ,but now on construction vehicles its showing the driver is wearing there seat belt
Offline LaserSteve
« Reply #9 on: October 09, 2020, 02:29:35 pm »
Where I live, even with seatbelt laws, a Nuclear Meltdown would be more preferable to most people, then seatbelt status lights.  Although I'm surprised the insurance mafia lobby has not tried to get that as a law.  In this state, a seatbelt violation is not primary cause for a traffic stop.  Simply because the greedy municipal or Mayor's  traffic courts  (Owned and Ran by the City) would love that.
I've seen those fixtures in an Automotive environment, years ago.  I do not know who makes them.  So I do a search for Green Warning Lights for Doctors, as I thought we had that on the books here, and I find "Feniex Industries " beacons.. The T3 in a single  or the Fusion Dual Stack Looks very much like what the OP is looking for.
Search Terms to try :  TIR LED Surface Mount Warning Light Heads
Steve
« Last Edit: October 09, 2020, 03:01:06 pm by LaserSteve »
Offline richard.cs
« Reply #10 on: October 09, 2020, 03:07:27 pm »
This kind of seatbelt light is used here *only* on construction equipment; diggers, road-rollers, bulldozers, etc. It's nothing to do with the law, it's about employers making sure their employees are following their internal rules. Just like requiring your construction workers to wear hard hats and steel boots.
