Author Topic: WHY? 1N400X  (Read 4532 times)
Offline innkeeperTopic starter
WHY? 1N400X
« on: September 08, 2017, 12:29:39 am »
OK, I've seen this question pondered before but never really seen a good explanation.
The garden variety 1N400x comes voltages from 50v to 1000V
but there all the exact same spec otherwise and same cost. ... so why bother with anything other then a 1n4007?
whats the point in bothering having multiple voltages?
Vishay spec sheet example:
http://www.vishay.com/docs/88503/1n4001.pdf
Hobbyist and a retired engineer and possibly a test equipment addict, though, searching for the equipment to test for that.
Offline NiHaoMike
    • Facebook Page
Re: WHY? 1N400X
« Reply #1 on: September 08, 2017, 12:53:53 am »
I remember reading that if you make a diode able to withstand a higher reverse voltage, it comes at the cost of a slightly higher forward voltage.
BTC: 18813fu8LQEdDwH9YLM1ABed3XwCfeSeFi
Offline coppice
Re: WHY? 1N400X
« Reply #2 on: September 08, 2017, 01:05:38 am »
Try ordering millions, and see if the cost is still the same when you start negotiating a serious price.  :)
Offline A Hellene
  • Country: gr
Re: WHY? 1N400X
« Reply #3 on: September 08, 2017, 02:22:17 am »
Higher blocking voltage->wider drift region->lower doping concentration->higher resistance->higher Vf at a given (high) current.
So maybe they all have 0.7V Vf at 0.1A, but if you apply a 10A pulse, you will start to see the difference.
Along with higher blocking voltages lower switching speeds come also; but in such slow diodes (~2.5 micro seconds) the difference is negligible. For the fast / super fast / ultra fast (and Schottky) diodes it makes a big difference, though.
BYV26's switching speed, for example, changes dramatically; from 30ns for up to 700V parts (BYV26A..C) to 75ns for the 900 and 1100V parts (BYV26D..E).
-George
« Last Edit: September 08, 2017, 02:31:37 am by A Hellene »
Hi! This is George; and I am three and a half years old!
(This was one of my latest realisations, now in my early fifties!...)
Re: WHY? 1N400X
« Reply #4 on: September 08, 2017, 02:44:54 am »
have you actually seen that with a 1n400x series. form what i have seen and what the specs say, seems not to be the case.
in fact the specs state the same vf for a given current for all in the series.
Re: WHY? 1N400X
« Reply #5 on: September 08, 2017, 02:54:45 am »
same prices
Mouser Part #:
863-1N4001G
Manufacturer Part #:
1N4001G
Manufacturer:
ON Semiconductor
Description:
Rectifiers 50V 1A Standard
1N4001G 1: $0.18
1N4001G 100,000: $0.017
Mouser Part #:
863-1N4007G
1N4007G
Manufacturer:
ON Semiconductor
Description:
Rectifiers 1000V 1A Standard
1N4007G 1: $0.18
1N4007G 100,000: $0.017
« Last Edit: September 08, 2017, 03:39:59 am by innkeeper »
Re: WHY? 1N400X
« Reply #6 on: September 08, 2017, 02:56:19 am »
It's common for manufacturers to rate Vf at worst case, so they can rate Vf at 4007 for all 400x devices.
It's also common for a manufacture to use the same die for 4001~4004, and a lower doping concentration die for 4005~4007.
Therefore, while the manufacture doesn't guarantee your 4001 to block 400V, it's likely it can.
that sounds a lot more likely.
Re: WHY? 1N400X
« Reply #7 on: September 08, 2017, 02:58:03 am »
me too, but seems not with these. its like there all the same part or soming
Online Someone
    • send complaints here
Re: WHY? 1N400X
« Reply #8 on: September 08, 2017, 04:31:26 am »
Historical probably:
https://electronics.stackexchange.com/questions/84471/what-is-the-difference-between-1n4001-and-1n4007-other-than-their-maximum-revers/84522
A part number and associated data sheet is just a specification, the actual parts delivered can change over the life of the product and come from different processes/foundries or for opamps even different designs! Tighter specifications on the forward voltages or forward resistance, reverse leakage etc are all available if you pay more for testing and get a new part number assigned. If you read the 1N400x data sheets carefully they mostly claim a "Maximum forward Voltage" which in the past could have been achieved with several different junction profiles/designs, but is now done easily with a single part.
I'd guess the biggest differentiator in the "unified" 1N400x lines would be that the maximum reverse leakage is specified at the rated DC voltage, so its a simple binning there with scope to downrate parts as demand arises. Leakages in diodes still varies quite a lot in production.
