Author Topic: Why are 24GHz presence sensors slow to respond?  (Read 675 times)
Offline e100Topic starter
« on: March 13, 2023, 09:49:45 am »
Does anyone know why the newer generation of human presence sensors operating in the 24-60GHz range take several seconds to respond to large changes in the environment?
Their slowness of response means that they are only useful when paired with a standard PIR sensor to trigger when someone enters a room.
However, once you are in the room they do a great job at detecting the tiniest of movements that the PIR sensor doesn't see.
« Last Edit: March 14, 2023, 07:02:11 am by e100 »
Offline MathWizard
Re: Why are 24GHz presence sensors slow to respond?
« Reply #1 on: March 14, 2023, 05:25:36 am »
Wow thats fast stuff, so can you would put that in a hallway or doorway as an alarm ? Well I'm suppused to make optical versions or something, but I never heard of such sensors before, and they are cheap, $20CAN.
I guess they talk right to a modem/or Bluetooth. When the power goes out I'll have to string up tin cans tho.
Online thm_w
  • Non-expert
« Reply #2 on: March 14, 2023, 09:05:14 pm »
Several seconds? It looks like its instantaneous.
But then you probably average over time to avoid false alerts.
9:30 in here:
Online PwrElectronics
« Reply #3 on: March 15, 2023, 04:15:12 pm »
Late 90s I was involved with a project to make a low cost ground speed radar.  We used transceiver modules from MACOM at IIRC 24.125GHz that were originally designed for automatic opening doors on stores/markets.
At the time, pre-GPS; there was a market for things like that for agricultural applications.  I think there is still a very small market for that sort of product but have not kept up.
