Author Topic: Why are good capacitors so expensive, and why don't they make these any more?  (Read 2837 times)
Online coppercone2
https://twen.rs-online.com/web/c/passive-components/capacitors/single-layer-ceramic-capacitors/?applied-dimensions=4294826632,4294880097
thats likely one of the best through hole capacitors money can buy.
gotta put together a kit >:(
« Last Edit: December 31, 2023, 10:59:35 pm by coppercone2 »
Online TimFox
So that’s what they’re calling them now.
Those are “disc ceramic capacitors” in 20th-century English.
Under that name and Ceramite brand, I used that exact series for RF purposes before retirement, and they worked very well.
A factory engineer gave me the power dissipation ratings for the different sizes, but I have lost the values.
Offline HalFET
Yeah, and the issue with that is also that the heat dissipation capacity of ceramic capacitors can actually change quite a bit depending on the exact construction, so it's a pretty good idea to only use figures from the manufacturer itself for that specific series. Something simple in a packaging step that has no appreciable electrical performance effect can have a tremendous effect on the ability to get heat out of the device, we ran into some serious issues with this when working in rarefied atmospheres because a manufacturer changed a packaging step (laser welding vs. ultrasonic welding) and it meant that the heat transfer to the component leads became less efficient, so we could no longer guarantee that all the devices on the board stayed within the specified temperature range in fault cases.
Online coppercone2
careful they have disk MLCC
those are SLCC
its a monolithic structure vs a cuban sandwich
Offline Roehrenonkel
Hi MathWizard, happy new-year,
may i point the gentlemen to my add:
https://www.eevblog.com/forum/buysellwanted/fs-(deeuww)-mica-caps-(nos-tht)/msg4052422/#msg4052422
...still have thousands of mica-caps.
Offline Zero999
  • 0999
Perhaps you can take a baby step into SMD by buying/designing a carrier that doesn't have a ton of capacitance or inductance.  It is easy to imagine something that would end up resembling a disc capacitor. Not elegant, but lets you do SMD on a very small scale to start.
Of my SMD parts, 1206 size and sot-23 BJT's seem it fit ok between the pads on my perfboard. And all the parts I checked, matched very close to their rating. So now I'm going to make a common-base Clapp oscillator, and compare it to the through hole part version I made last week.
That's what I do, as mentioned above.
For SOT-23 transistors or ICs, I use a drill to cut the track, solder pin 3 to the uncut track and pins 1 & 2 either side of the hole when the cut in the track is. I also do the a similar thing with SOT23-5 and  SOT23-6, with the four outer pins soldered between the cut tracks. I connect the middle pins to other tracks with short pieces of thin wire.
Offline MathWizardTopic starter
Well with standard, 1 sided ring-pad perf-board, and 1206 parts, I used my strong flux, and it got under the parts ,and there's a bit of DC leakage messing with the biasing. I used steel wool on the perfboard 1st, so I should have used my safer flux. Without extra flux the wetting takes too long, and doesn't spread the solder near as good.
And 1206 was a little over sized. So I just made an 0805 amplifier circuit, and those fit much nicer between the ring pads, without overlapping.
But what I did 1st this time, was tin a pile of pads, but that filled them all in, so I had to go back with solder wick to remove most of it. Then to get nice clean bonds, I tinned all the parts too. Then I just had to lay them in place and tack 1 side at a time, and check resistances before adding caps.
But yeah I'm quite happy with that. All my SMD parts are cheap ebay/amazon ones, and they are all way closer to their ratings. And have lower parasitic's too, are and cheaper.
I have lots of breakout boards for chips or transistors if needed. I have some Dremel accessories that might make cutting up copper clad boards easier, but I haven't tried any of them yet.
« Last Edit: January 01, 2024, 05:30:23 pm by MathWizard »
Online TimFox
those are SLCC
The “disc ceramic capacitor” is a disc of ceramic dielectric material, metallized on both flat sides, with wires soldered to the metal layers, then dipped with insulation.  They are still useful for working voltages impracticable for MLCC construction.
Most ceramic caps nowadays are MLCC, with a monolithic structure stacking multiple layers of metal and ceramic.  This new term SLCC seems to be a retronym for the older construction.  A MLCC with wire leads and axial or radial construction is not a disc, but quite useful for reasonable voltages.  I like the mil version (e.g. CCR06) with molded square plastic housing, since they look appropriate when fully seated against the PCB, but they are more expensive than the conformal packaged units that work equally well, but look less neat.
Another nostalgic NP0 ceramic cap is the “dogbone” style found in Tektronix ‘scopes.
Online coppercone2
look at this one.
IDK if its a MLCC or a SLCC misrepresented as a MLCC
https://www.meritekusa.com/products/capacitors/high-voltage-ceramic-disc-hv-series/
I also had a round blue one that did not look like the little pillow but claimed to be a MLCC, even with the SLCC shape. It was fatter then a typical disk cap, blue, but IIRC the data sheet said it was a MLCC.
Offline Zero999
  • 0999
I only use the adaptor boards for SOIC.
I fit SOT-23 parts directly to the board, with the tracks cut to make them fit. For 5 and 6 pin devices, I connect the middle pin via copper enamelled wire, shown in red on the picture.
Online TimFox
look at this one.
The one pictured there looks very like a disc:  note the wire connection under the coating running on the bias.
The data sheet lists several dielectrics, including C0G/NP0, X7R, … , Z5U, which would be required to cover that range of capacitance at high voltage.
