Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
Why are the commands in includes in MPASM suite, different to expected?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Why are the commands in includes in MPASM suite, different to expected? (Read 2183 times)
iamwhoiam
Contributor
on:
June 03, 2012, 10:55:16 pm »
Hi folks
Just been following a tutorial, and instead of _DATA_CP_OFF, inside "P16F628A.INC" the directive:
Code:
[Select]
_DATA_CP_OFF
is changed to:
Code:
[Select]
DATA_CP_OFF
NO leading "_" underscore... :-S
Any ideas why?
TIA
Logged
Mechatrommer
Super Contributor
Country:
reassessing directives...
Re: Why are the commands in includes in MPASM suite, different to expected?
Reply #1 on:
June 04, 2012, 07:23:42 am »
Quote from: iamwhoiam on June 03, 2012, 10:55:16 pm
Any ideas why?
no idea! ask the "creator" (or from where you get the file). you edit either your file or the inc to make them compatible, then you good to go. but changing the later is not advisable.
Logged
oPossum
Super Contributor
Country:
Very dangerous - may attack at any time
Reply #2 on:
June 04, 2012, 12:36:03 pm »
The first is typically used with the __config directive for parts with one config word. (most 10F, 12F, & 16F)
The second is typically used with the config directive for parts with several config words (18F)
Logged
codeboy2k
Super Contributor
Country:
Reply #3 on:
June 04, 2012, 08:57:54 pm »
identifiers that
1) begin with a single underscore; or
2) contain a double underscore anywhere in the identifier
are reserved for the C or C++ implementation and should not be used by authors or library authors.
Chances are they wanted the MPASM libraries to be standards compliant.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
