personally i have never used a fibreglass pen so i cannot speak for them, however based on your images the pads look to have reflowed fine,
One remark i will make is if you are using a hakko 888D (common one beginners end up with), make sure you read the manual and check its calibration, every few months another worker will try and set the temperature on that model and end up mis-calibrating the iron instead where i work,
the cheap thermocouple your multi meter likely came with is good enough for this task, lightly tin the tip then hold it against the iron and note the temperature, (you will likely be within 15 degrees or so)
