When the Chinese (or other Far Eastern country with massive power supply design/manufacture industry) need to build a power supply for a low-volume application, they will do it much better than the West
Yes, ----
If they either go to a large specialist supplier like Meanwell, or poach someone who has worked at one.
If, as seems to be the case sometimes, they grab some "rent an Engineers" off the street, they will get something designed from a manufacturer's application note.
The SMPS on some "custom designed" transmitters I worked on were made the latter way, as was the RF design.
As soon as the EEs have done their work, they are "let go", so there is no continuity.
The equipment I am referring to were definitely "low volume" ( there were only five ever made)!
It wasn't really the PSU's fault that they were "smoked"-- it was a power level control which oscillated at 18kHz, over modulating (AM) the PA stages of these supposedly CW transmitters ("rent an EE" strikes again!).
I have seen failed SMPS before, but never have I seen anything as "cooked" as these were.(not repairable).
After much correspondence, we got a new board for one, which was pre mounted on a different sized heat sink, so we had to refit it to the old one or it wouldn't fit into the required space.
From this, it is evident that even in China, small volume manufacturers don't always go to the major suppliers.
I am willing to bet that, if they had gone to Meanwell, the supply would have survived the abuse, & if it had failed, would be repairable.
As to Chinese expertise in microwave work ( although you limit the comment to the,similarities to EMC problems), my experience may give me a jaundiced view, but the level of RF design knowledge revealed by the equipment referred to above points to a "look on the Internet"level.
This company claimed they also supplied transmitters for TV Broadcasting in their home country.
Either they were lying, or Chinese transmitter Techs are the best, (& most stressed) in the world!
Obviously, the big players do it right, but with "small volume" from China "you pays your money, & you takes your chance".
