Author Topic: Why Battery Voltage Varies Between Different Testers?  (Read 2067 times)
Offline Boris_yoTopic starter
  • Country: il
« on: September 18, 2022, 04:12:06 am »
Hi. Tested new alkaline battery 1.5v and here are the readings I got:
1. Chinese battery tester: 1.27v
2. Aneng brand Chinese battery tester: 1.50v
3. Chinese multimeter: 1.53v
Used lithium AA single-use battery:
1. Chinese battery tester: 1.23v
2. Aneng brand Chinese battery tester: 1.48v
Tested Sanyo 2500mAh barely charged AA battery:
1. Chinese battery tester: 1.03v
2. Aneng brand Chinese battery tester: 1.11v
Tested 9v alkaline rectangular battery:
1. Chinese battery tester: 8.85v
2. Aneng brand Chinese battery tester: 9.12v
It seems that while multimeter puts on zero load, the battery testers put a tad bit. Though why readings between both battery testers vary?
« Last Edit: September 18, 2022, 04:16:00 am by Boris_yo »
Offline Ed.Kloonk
  • Cat video aficionado
Re: Why Battery Voltage Varies Between Different Testers?
« Reply #1 on: September 18, 2022, 04:30:35 am »
Are these 'testers' analog meter variety? The cheaper the meter component the more inaccurate they are.
A analog meter is supposed to considered *most accurate at FSD (full scale deflection). Connect them to a good variable power supply and set the output to what the maximum range the meter should read. If that is anywhere near accurate, then check the meter at 1/4, 1/2, 3/4 range to see how good it is.
edit: most
iratus parum formica
Offline WattsThat
« Reply #2 on: September 18, 2022, 04:32:22 am »
Yes, battery testers load the battery, a multimeter/DMM does not.
The following users thanked this post: Ed.Kloonk
Offline Ed.Kloonk
« Reply #3 on: September 18, 2022, 04:36:17 am »
I see now the question asked. Disregard my answer. Sorry.
Offline tooki
« Reply #4 on: September 18, 2022, 04:33:24 pm »
::snip::
Yes, a multimeter places essentially no load, while a tester places a load. As for the differences — well, think about it for a moment: what would cause a difference in measured voltage? Give us your hypothesis and we’ll let you know if it’s right.
Online bdunham7
« Reply #5 on: September 18, 2022, 05:01:13 pm »
I think your generic or unnamed "Chinese battery tester" is the one getting the job done here...
Online ledtester
« Reply #6 on: September 18, 2022, 05:05:51 pm »
Which one is your Aneng tester? Does it look like this:
1593901-0
Online BeBuLamar
« Reply #7 on: September 18, 2022, 09:07:37 pm »
Connect a power supply set for 1.5V with rather hefty current capacity (at least 2A) and see what the #1 tester reads and how much current does it draw from the power supply.
Offline unknownparticle
« Reply #8 on: September 19, 2022, 05:57:51 pm »
Some DMM's have a dedicated range for 1.5 and 9 volt batteries, which place a load across the cell. This gives a more realistic idea of the cell capacity.
DC coupling is the devils work!!
  • Country: il
« Reply #9 on: October 04, 2022, 08:46:32 am »
Impaired conductivity of battery tester? I used electronics contact spray on the one giving lowest reading and it still does. Probably has some kind of internal resistance or crappy components.
Quote from: ledtester
That's the one. Also here's the multimeter face. For voltage reading I set on 2 under V-
Offline Nominal Animal
« Reply #10 on: October 04, 2022, 11:48:15 am »
No.  A battery is not a perfect voltage or current source, it has real world characteristics.  Consider what those characteristics are.
Offline SmallCog
« Reply #11 on: October 06, 2022, 01:53:49 am »
I suggest you probe the battery with the meter whilst it's being tested by the battery tester.
Theoretically you'll see more similar readings between the meter and tester as the meter will be reading the loaded battery
The following users thanked this post: Boris_yo
Offline Kasper
« Reply #12 on: October 06, 2022, 05:10:01 am »
Measure the battery current during the battery test to check for differences between testers.
Offline tooki
« Reply #13 on: October 06, 2022, 06:21:22 am »
No, it’s not that.
Earlier, you mentioned the battery tester applying a load. That is correct. Now, what poses a higher load (= more current flow): a smaller resistance or a larger one?
  • Country: il
« Reply #14 on: October 10, 2022, 06:40:04 am »
Quote from: tooki
Are you talking about resistance of battery or impedance of battery tester?
Offline tooki
« Reply #15 on: October 10, 2022, 01:30:55 pm »
It’s a general question to see if you understand Ohm’s law.
