Can a shadow move faster than light? It can, but you can't use that effect to send information faster than the speed of light. (That is the modern version of the law.)
So some of you are saying that when I have a long row of people and start a Mexican wave by having everyone stand up at the same or almost the same time, the Mexican wave travels faster than light?
Quote from: NiHaoMike on June 09, 2018, 01:12:02 pmQuote from: JohnnyMalaria on June 09, 2018, 12:33:45 amNo it's not.If you are male, have a full bladder, take a whiz outside and pee in one place, you'll get a puddle (unless you're standing over a drain or the edge of a cliff). If you point Percy at a different location, you'll get another puddle. If you wiggle your thingy back and forth then you'll see that the stream of water is actually a series of discrete droplets (single chamber choked flow atomization). If you do it fast enough then the puddle of water will seem to move fast - faster than it should. But each puddle is made by pee droplets emitted in that direction. How the first puddle came about has absolutely no relation with the second. There is no correlation. This is what's irrelevant.Of course, in this experiment you'd have to be able to pee like a shire horse with tremendous velocity sitting on a merry-go-round and spinning at very high speed. (If you're not male then you are missing one of life's wondrous gifts )Why can't a girl do it?She can. But her aiming apparatus is not as flexible.
Quote from: Mr. Scram on June 09, 2018, 08:42:14 pmSo some of you are saying that when I have a long row of people and start a Mexican wave by having everyone stand up at the same or almost the same time, the Mexican wave travels faster than light?And how are you going to tell the participants when it is time to stand up?
Give them watches and tell them when to stand up. Where is the problem?
