Those Littelfuse tables bring back memories, especially of the PSU protected by 3 1A solder in Littelfuses, where the most common cause of a
PSU failing was a shorted diode ( one of 42), and if 2 shorted out in the same rail it would cook the transformer. The fuses would only blow ( 2 out of 3) after the transformer had well and truly cooked itself into a ruin. I used to check the power rails on every unit, irrespective of why it came in, with a scope looking for the odd shaped ripple that indicated a shorted or open circuit diode. I got a few open circuit diodes that way, and a single open or shorted diode would have very little observable difference on the rails aside from the missing cycle in every 6. Of course the original MC44 diode was obsolete........
