Author Topic: Why do quotes screw up when modifying posts and how do I make it stop?  (Read 802 times)
Offline MarkSTopic starter
As the title says. I've tried the "Toggle View" button, and that turn the HTML back into BBCode, but the quotes are changed in the process. How do I fix/stop this?
« Last Edit: March 27, 2023, 03:33:51 pm by MarkS »
Online Someone
    • send complaints here
Default to the bbcode editor (setting in your profile "Look and Layout"). Swapping between the two with text present is destructive/non-reversed.
or... swap before you add the quote(s) and then use the Insert Quote button on the posts below the editor.
The following users thanked this post: MarkS
Offline Infraviolet
On every forum I've ever used I avoid the quote function anyway. Because when someone later tries to read through your thread at a future time because it sounds relevant to their future problem, then they find the whole thing broken up by blocks of repeated quotes, and the whole page far longer to scroll through than needed. Especially bad are cases where someone quotes someone who is already quoting another post...
I tend to prefer noting in my reply post the username or post number of a post I'm replying to, or if I need to quote something just copying and pasting the single phrase or sentence of the original text and showing it "just in normal quote marks".
The following users thanked this post: PlainName
Online thm_w
  • Non-expert
Sounds like more hassle than its worth, use the quote button and remove excess text/photos if you think its too long.
Exactly. If it's a long post and I'm replying to the entirety of it, I'll replace the text with "...snip...". That way, It's clear as to which reply I'm replying to, but not overwhelmed with text.
Offline EPAIII
Yes, I like using the "...<snip>..." to remove text that is not relevant to my post. I wish there was a button to insert that.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Simple, most of us have done this at some time.  :-[
In your profile you have the WYSIWYG editor set to ON, turn it to OFF.
