Why does cold temp has a limit of -273C/0k and high temp has no limit?
Posted by
MrOmnos
on 16 Dec, 2016 16:11
How hot can it get?
#1 Reply
Posted by
Arjan Emm
on 16 Dec, 2016 16:24
Physics thinks the highest possible temperature is the Planck temperature, around 1.4*10^32 K. So there is probably a limit. It's just strange that it's so incomprehensively high and -273 is so close to our comfort zone.
How incomprehensible?
supernovae around 10^10K
Large hadron collider 10^18K
Anything a few decades higher is bigbang theory.
#2 Reply
Posted by
SeanB
on 16 Dec, 2016 16:38
Look at in in Kelvin, where zero kelvin is where all atomic motion ceases. You cannot have lower energy than zero, but the high limit is set by the ability of the universe to contain the particle travelling at C.
Best we have reached is ca 0.01K, and that is really hard to get to, and where measuring the temperature is very difficult, as the measurement adds energy to the system. Below around 0.5K many things behave as a single particle, or at least He does, which is the gas most commonly used.
#3 Reply
Posted by
Spuddevans
on 16 Dec, 2016 16:43
Is it something to do with the point that you can't directly generate cold, you can only remove heat, but you can always inject more energy, ie add heat.
#4 Reply
Posted by
grumpydoc
on 16 Dec, 2016 16:44
#5 Reply
Posted by
Gyro
on 16 Dec, 2016 16:48
It's always struck me as a bit odd too that we exist at such close proximity to absolute zero. Yes I know it's down to our chemistry but it still feels a bit strange that you can reach an equivalent temperature differential in the oposite direction with a bog standard soldering iron!
#6 Reply
Posted by
Benta
on 16 Dec, 2016 16:54
Just to correct the original question:
Absolute zero is 0 K
Which corresponds to appr. -273 degrees Celsius.
There is no such thing as -273 K.
#7 Reply
Posted by
Kleinstein
on 16 Dec, 2016 16:58
If we are close to zero temperature depends on the scale on a logarithmic scale, there is plenty of room to both directs. The lowest temperature reached are also quit a bit lower than 10 mK. Those experiments with Bose-Einstein condensates are at micro kelvins.
With non equilibrium systems, there are different ways to define a temperature. One is to look at the population of two states of different energy. The higher the temperature the more equal probabilities for the two states. However for some reason the higher level is more likely than the lower one, one could call this a negative temperature - or one higher than infinite, depending on how you look at it.
#8 Reply
Posted by
Arjan Emm
on 16 Dec, 2016 17:29
I agree with your feeling. But it is not down to our chemistry but chemistry in general. Molecular bonds are really weak, that's also why they can get as complicated as us humans. Between 400 degrees C and say 2000C most big molecules fall apart. At only 10.000K chemistry ceases to exist and all you have is single atoms, many already stripped of many of their electrons.
#9 Reply
Posted by
Arjan Emm
on 16 Dec, 2016 17:51
Good points. I guess cooling down to almost 0 K, let's say 10^-30 K is just as impossible to achieve as 10^30 K heat.
It is a consequence of when we live in the age of the universe. When the universal background is down to 3 K.
Arthur C. Clark expressed it poetically. He spoke wistfully of what it might have been like to live in the early universe, when everything was close by and high energy events were commonplace. When entropy had just started to increase. He then predicted that far in the future, as the heat death of the universe neared, any intelligences living then would be wistful of us who lived when the universe was young.
#11 Reply
Posted by
0xdeadbeef
on 16 Dec, 2016 18:41
As a side note it might be worth mentioning that also the pressure range is not very symmetric from our perspective. The absolute vacuum is just 1bar (or 100 kPa) away but it's relatively simple to achieve pressure values that are magnitudes higher and near the code of our planet, it's supposed to be 330 Gigapascal, letting aside Neutron stars and the like.
I guess as with the temperature and other things, it's just a matter of anthropocentric worldview: as we can only exist in certain conditions, it's pointless to wonder why the conditions allow us to exist. As if they wouldn't, we couldn't wonder.
#12 Reply
Posted by
ajb
on 16 Dec, 2016 19:45
True, phillosophically one could argue that the Earth was designed as a low power system
#14 Reply
Posted by
tszaboo
on 16 Dec, 2016 22:25
Yeah, well the other spectrum, electronics does not really work in the picoherz and the terahertz region.
#15 Reply
Posted by
T3sl4co1l
on 17 Dec, 2016 00:09
It's analogous to saying "there is no voltage [magnitude] below 0V". And that thermal noise guarantees you will always have slightly more than zero, no matter how you measure it (except also at absolute zero temperature).
Different particles, and different aspects of the system, can possess different temperatures. A system need not always be in perfect equilibrium; there needn't even be an exchange mechanism between the different parts of the system. (Thermodynamics assumes there will eventually be some sort of exchange, which in real systems, always manages to happen in the end. Over finite time scales, things can be very different: by pumping a magnetic field, you can chill the nuclear spins of any nonzero-spin atoms. The heat energy contained therein is extraordinarily small, of course, but it's also fascinating that the thermal time constant is in the tens of seconds -- for a quantum system that's room-temperature (or not) and quite low energy (~ueV per flip).
#16 Reply
Posted by
LokiChaos
on 17 Dec, 2016 00:20
Negative absolute temps are very different than one colloquially thinks of temperature, they are a result of systems with high constrained sets of possible states, and a definition of temperature grounded in statistical mechanics.
The interesting thing is negative temps are HOTTER than any positive temp, not colder. Energy always flows out of a negative absolute temp systems into a positive temp one.
https://en.wikipedia.org/wiki/Negative_temperatureA commonly encountered system is in a laser in a state of population inversion.
#17 Reply
Posted by
Tinkerer
on 17 Dec, 2016 01:18
Well, I dont think asking why we exist so close, relatively speaking, to absolute zero is the correct question. The question should be why are the energy levels needed for chemistry to exist so close to absolute zero. At higher temperatures, you dont really get much chemistry happening, its all mostly gas and plasma as the atoms are too energetic to to chemically interact in most cases.
The above leads to an interesting thought. What if electrons and such were more strongly bound to their respective atoms? etc etc, what if bonds were much stronger?
#18 Reply
Posted by
LokiChaos
on 17 Dec, 2016 02:11
You'd end up with a lot less chemistry happening as most places would be too cold to have large numbers of interesting reactions (this would also likely preclude life in a sense we are familiar with).
Chemical reactions of all sorts would be rarer, but those that do occur would be far more energetic and the products far harder to break apart. There are a lot of different effects, some depend on if you just increase the strength of the electromagnetic force, or increase the charge quanta, or if the other fundamental forces also scale as well.
#19 Reply
Posted by
T3sl4co1l
on 17 Dec, 2016 04:32
What the hell does that mean? In other words -- relative to what?
#20 Reply
Posted by
neil t
on 17 Dec, 2016 05:14
It's all relative to what we can and can't measure or prove or disprove ie supposing nothing travels faster than the speed of light if It did could it be measured with current technology.
or would it be measured by unproven theory. based on what we know or think we know at this time.
Bose Einstein Condensate.
#22 Reply
Posted by
LokiChaos
on 17 Dec, 2016 06:17
At very low temps quantum effects crop up at a macroscopic level because the number of states is so restricted that the normal classicalization that happens in statistical mechanics can no longer occur. You get second sound, third sound, new states of matter, superconductivity, superfluidity, etc.
In some ways it's a shame we generally exist at such /high/ temperatures, imagine if we could have superconductive materials at our "room temperature"!
#23 Reply
Posted by
Galenbo
on 17 Dec, 2016 12:05
How hot can it get?
When I was 12y old, or before physics studies, I would have understood it like:
* Temperature in Kelvin is like the amount of inside random movement.
* 0K = zero movement
* Random movement is not directional. It's like light on, light off, light half on.
* Much movement creates heat, you can feel it on the surface.
Once you get down to 233K, anything colder and it all feels the same to me.
French swears start coming out at that temp.
