Author Topic: Why does NTSC use a strange frequency for the chroma carrier?  (Read 4919 times)
Online BrianHG
    • LinkedIn
Re: Why does NTSC use a strange frequency for the chroma carrier?
« Reply #25 on: January 14, 2023, 09:40:25 pm »
This is what it looks like if your video frame rate doesn't match you AC's source line frequency and there is some magnetic flux leakage into your picture tube via magnetic or electrical drive:
(Seek to 3:33.)
If the MCU outputted that logo at a perfect 60hz refresh cycle speed, even through there may be a slight warping in that image, the warp pattern would have been static still and not visible.
« Last Edit: January 14, 2023, 10:22:52 pm by BrianHG »
Offline Ben321Topic starter
« Reply #26 on: January 16, 2023, 12:25:26 pm »
Now days we have solid state drive circuits for CRTs that can much better produce the precise horizontal and vertical scanning frequencies. For example, VGA CRT computer monitors could easily be driven at 75Hz or 85Hz vertical scanning rate for more flicker reduction (the faster the vertical scan rate, the less the picture appears to flicker to the human eye).
Online BrianHG
    • LinkedIn
« Reply #27 on: January 16, 2023, 01:30:55 pm »
Yes, but even with a top of the line studio multiscan CRT, here in North-America, at 75hz, in some locations we can see the image wobble 15 times a second due to high power tension lines being within a block of your location.  It doesn't matter how good the CRT electronics are if you are bathed in a 60hz magnetic field like I am during the coldest winter days and hottest summer days where the high tension power lines 2 blocks from my how radiate such a strong field, I can measure AC voltage on disconnected transformer cores, large ones giving enough to light a LED.  The next non-wobbly vertical scan rates step up is 90hz or 120hz video.
Offline james_s
« Reply #28 on: January 16, 2023, 08:37:17 pm »
I've seen houses that are directly under or very near high tension transmission lines. I always thought it would be interesting to put a large coil in the attic and see how much power could be extracted from that.
Online BrianHG
    • LinkedIn
« Reply #29 on: January 17, 2023, 06:09:43 am »
Like these: https://shop64002.carrierwrt.org/category?name=fluorescent%20light%20under%20power%20lines
Yes, most if not all of those are real.
Thanks to a 25 foot metal beam which was the edge of my workbench desk at my house, if I placed 1 electrode into the ground and one on that desk beam as an antenna, I got around 1watt of free power.
Offline Assafl
« Reply #30 on: January 17, 2023, 07:39:14 am »
You can literally light an LED? That is cool. You could energy harvest some from those utilities. Get that Poynting vector into your house.
I'd love to tell the utility guy: I am stealing energy from you and there is nothing you can do about it.
Great way to show that while the cables are important for setting up the energy fields - the actual energy flows through households blocks away.
So if you host a party and say "feel the energy" to what energy are you referring to?
Offline EPAIII
« Reply #31 on: January 19, 2023, 09:50:43 am »
Yes, way back when the TV industry was being invented they needed every trick they could conjure up. So, using the power line as a field synchronizing rate did solve some problems. How much so, I am not sure. That went away fairly quickly. But the numbers remained.
Back in those ancient days, the TV cameras also did not have any definite relationship between the horizontal and vertical sync rates. I mean, just how do you design a TUBE circuit that multiplies 60 Hz up to 15750 Hz, with stability? I do not want that job. So yes, if you are taking the vertical scan rate from the power line, then the horizontal rate will be drifting free of that vertical rate. This went away real fast as TV developed. And the two frequencies were tied together in a strict relationship, both in terms of frequency and phase.
Among other things that needed this relationship was the serrated vertical sync pulse in the vertical interval. Tube circuits in TV sets were ANALOG oscillators that had to be kept synchronized with the sync pulses in the video signal. Remember that the NTSC video signal is interlaced: 262.5 lines forming field one followed by another 262.5 lines forming field two. And those two fields had to be timed to start properly to keep the adjacent lines separated. A small timing error in the start of the vertical sweep could mean that the lines of field 2 could be on top of field 1. So the vertical oscillator in the TV set had to start very precisely (for tube circuits) for both fields. And at the same time that the vertical sync pulse was being transmitted, the horizontal sync information (pulses) needed to continue so that the horizontal circuits did not lose step. So the vertical sync pulses, which were three horizontal lines long, were serrated by the horizontal sync pulses. BUT, if the vertical sync pulses at the start of the two fields were just serrated at the horizontal rate, then one would end with a pulse that is a full H line long while the other would have a final pulse that is only 1/2 as long. That would mean that the OLD FASHIONED tube oscillator circuits would have a hard time starting in the correct time intervals. One would be sooner and the other later. And the lines of the two fields would start to overlap while a black band appeared between them. Not good.
So they increased the horizontal pulses to twice the 15750 Hz rate during the vertical interval for a full 21 horizontal lines. The horizontal oscillator could ignore the extra pulses while the vertical oscillator saw six vertical pulses that each lasted for 1/2 the horizontal line's duration. Both of these serrated vertical sync pulses, with six divisions, lasted for three horizontal lines' time and both appeared the same to the vertical oscillators which needed that advantage in the early days of tube type TV sets.
This is one big reason why the idea of locking the H and V sync rates together was a MUST. It is a major reason why the idea of using the power line frequency as a reference was VERY QUICKLY abandoned. Once NTSC was standardized for B&W TV, there was no more power line reference. PERIOD.
But, as I said, the numbers remained. Part of the reason why that happened is likely explained by the various OEMs of the broadcast equipment and the home TV receivers reluctance to give up any of the market share they had in those industries. There had to be agreement on what was done so that the equipment would be compatible. This need for compatibility was repeated when color TV came along. I can remember the ads for the various TV sets claiming how they were "compatible" with each other and with B&W TV. It wasn't all strickly technical reasons. Some of it was marketing.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
