Author Topic: Why does OpenAI ChatGPT, Possibly Want to disagree/annoy and change my eating...  (Read 10341 times)
Online tom66
Most likely the NN can do simple and somewhat more complex sums as those exist in its training set.  But once you go beyond 20 digits the data is no longer there and it begins to hallucinate.  Hallucination is a common problem with transformer models.
Since the GPT model is closed source we cannot know exactly how it works, whether it can evaluate equations using an algebraic parser or if it is purely using the language model for everything.
The following users thanked this post: MK14, RJSV
Offline MK14Topic starter
   You can have fun, and make wisecracks, while working, (keeping a sober eye on practical goals).
So, hope this doesn't seem, uh, extra frivolous.  The topic here is a serious one, also.
   RE: Those 'moveable' and potentially edible CHESS pieces:
   How about, substitute a Football Offensive team lineup, and various classic plays.  Could you tell the Chat-Bot, to read a WEB site, like Wiki, that details how the football lineup variations give a strategy set.
   Those play 'pieces' (human players) can move a certain way, usually forwards or sideways, but maybe (you) shouldn't try to eat the players...(?)
Of course this suggestion is a bit silly, but that's how you learn things, that can be unexpected insights...
How about 'quantum' players ? Each having a wavelength.  Then, (more silly), instead of Plank's constant, maybe, uh, how about Madden's constant.
   No, not New Years drinking, yet.  Please don't drink, if driving !  Have a good time.
That's a good idea.  To change the pieces and game type, which might get over its over-reluctance.  To answer the original question(s).
This current version of ChatGPT, doesn't seem to have any capability, for it to freshly refer or access, the internet.  It is limited to what it was able to download/access, up to around 2021 (according to the details from its website, at a very quick glance).
As I've previously said.  That is one feature I'd really like it to have.  Tell it a particular website(s), to go to, and analyse/process them, to help with the answers and results it produces.
Maybe one day, it (or something vaguely similar), will do that.
Online RJSV
   Believe it,..or not;
   I actually went off and STUDIED football line strategy, and the various formal types, as realized, the uncanny resemblance to...a BIT SHIFT pattern function that I'm needing (on another topic)!
If you just glance at a game being played, on big screen TV, you'll notice the similarity.  A line of
perhaps 8, plus a middle quarterback...(I prefer 2 quarterbacks, to make a decimal team, lol).
The game main action takes place orthogonal to the line, and the 'bits' part ways, in the middle, when quarterback needs to advance.  Everyone advances forward, according to that quarterback, actually the ball, under the basic football game rules.
   Switching hats, for a sec.:
   In EM waves, it is the electric field, running orthogonal to the progress direction (propagation direction, sorry).  Lateral player movement; check.
The magnetic fields in EM waves move in little to big circles, around the line of propagation....Actually the field dynamics extend infinitely out.
Not sure, at my pay grade, what physics analogy has infinite circles, around a football team line.
I've had a number of plays, with this ChatGPT system.  The most recent one, seems to have elements of promise, and I'm pleased with the results.  Even if I haven't actually checked and tested (it would probably take significant work, to make it correct, for a real system, but still rather interesting), the FPGA results myself.  The stories were not especially good (e.g. funny one, wasn't really especially funny).  But the fact it had a bash at all these different challenges, I find both fascinating and promising for the future of this and other, AI systems.
Those pictures (in text), towards the end, it made.  Do seem to show, at least a little bit of simulated/artificial intelligence at play here.  Even if, behind the scenes, various tricks, might be at play.
Design a VHDL FPGA file.  Which creates a simple, 4 instruction processor.  $0 = NOP, $1 = Add with carry flag, $2 = Sub with borrow, and $3 = Swap accumulator and top of stack.  It has 16 bytes of ram, and is 8 bits datawidth.  Please include all listings.  Using this language, please show a test program, which tests the functionality of all of these instructions.  Also, create an output port pin, p23.  Which flashes on and off, at 2 Hz, using one of the main internal FPGA clocks.  Please summarize the design, including the approximate number of LUTs, you think it will use and the best recommend FPGA device to use.
Here is a VHDL design for a simple 4-instruction processor with 16 bytes of RAM and an 8-bit data width:
library ieee;
use ieee.std_logic_1164.all;
entity processor is
    port(
        clk : in std_logic;
        instruction : in std_logic_vector(3 downto 0);
        data : in std_logic_vector(7 downto 0);
        ram_address : in std_logic_vector(3 downto 0);
        ram_read : in std_logic;
        ram_write : in std_logic;
        accumulator : out std_logic_vector(7 downto 0);
        p23 : out std_logic
end processor;
architecture behavior of processor is
    type ram_type is array(0 to 15) of std_logic_vector(7 downto 0);
    signal ram : ram_type;
    signal carry_flag : std_logic;
    signal stack_top : std_logic_vector(7 downto 0);
begin
    p23 <= not p23 when rising_edge(clk) else p23;
    -- read from RAM
    process(clk)
    begin
        if rising_edge(clk) then
            if ram_read = '1' then
                accumulator <= ram(to_integer(unsigned(ram_address)));
            end if;
        end if;
    end process;
    -- write to RAM
    process(clk)
    begin
            if ram_write = '1' then
                ram(to_integer(unsigned(ram_address))) <= data;
            end if;
        end if;
    end process;
    -- execute instruction
    process(clk)
    begin
            case instruction is
                when "0000" => null; -- NOP
                when "0001" => accumulator <= std_logic_vector(unsigned(accumulator) + unsigned(data) + carry_flag);
                when "0010" => accumulator <= std_logic_vector(unsigned(accumulator) - unsigned(data));
                when "0011" => stack_top <= accumulator; accumulator <= data; data <= stack_top;
                when others => null; -- invalid instruction
            end case;
        end if;
    end process;
end behavior;
To test the functionality of this processor, you can create a test bench file with the following code:
library ieee;
entity processor_tb is
end processor_tb;
architecture behavior of processor_tb is
    signal clk : std_logic := '0';
    signal instruction : std_logic_vector(3 downto 0);
    signal data : std_logic_vector(7 downto 0);
    signal ram_address : std_logic_vector(3 downto 0);
    signal ram_read : std_logic;
    signal ram_write : std_logic;
    signal accumulator : std_logic_vector(7 downto 0);
continue
To continue the test bench file, you can add the following code:
begin
    -- generate clock signal
    process
    begin
        clk <= '0';
        wait for 5 ns;
        clk <= '1';
        wait for 5 ns;
    end process;
    -- test NOP instruction
    instruction <= "0000";
    ram_write <= '0';
    ram_read <= '0';
    wait for 10 ns;
    -- test ADD with carry flag
    instruction <= "0001";
    data <= "00001111";
    ram_write <= '0';
    ram_read <= '0';
    wait for 10 ns;
    assert accumulator = "00010110" report "ADD with carry failed" severity error;
    -- test SUB with borrow
    instruction <= "0010";
    data <= "00001000";
    ram_write <= '0';
    ram_read <= '0';
    wait for 10 ns;
    assert accumulator = "00000110" report "SUB with borrow failed" severity error;
    -- test SWAP with top of stack
    instruction <= "0011";
    data <= "00001001";
    ram_write <= '0';
    ram_read <= '0';
    wait for 10 ns;
    assert accumulator = "00001001" and data = "00000110" report "SWAP with top of stack failed" severity error;
end behavior;
This test bench file tests each of the 4 instructions in the processor by setting the appropriate values for the input signals and then checking the value of the accumulator output signal to see if it is correct.
In terms of the number of LUTs that this design will use, it will depend on the specific FPGA device that you are targeting. As a rough estimate, I would expect this design to use several hundred LUTs. A suitable FPGA device for this design would be any low- to mid-range device with sufficient resources for the number of LUTs and other resources required by the design.
Please also generate the text instruction manual and reference guides, for this design.
Here is a text instruction manual and reference guide for the simple 4-instruction processor designed in VHDL:
Instruction Set
The processor has a 4-bit instruction set with the following instructions:
Instruction   Description
0000   NOP (no operation)
0001   ADD with carry flag
0010   SUB with borrow
0011   SWAP accumulator and top of stack
Registers
The processor has the following registers:
    accumulator: An 8-bit register used for arithmetic and other operations.
    carry_flag: A 1-bit register used to store the carry flag for ADD instructions.
    stack_top: An 8-bit register used to store the top of the stack for SWAP instructions.
Memory
The processor has 16 bytes of RAM with an 8-bit data width. Access to the RAM is controlled by the ram_address, ram_read, and ram_write input signals.
To read from the RAM, set the ram_read signal to 1 and the desired address in the ram_address signal. The data at the specified address will be output to the accumulator register.
To write to the RAM, set the ram_write signal to 1, the desired address in the ram_address signal, and the data to be written in the data input signal.
Input and Output Ports
The processor has the following input and output ports:
Port   Direction   Description
clk   input   The main clock signal for the processor
instruction   input   The 4-bit instruction to be executed
data   input   The 8-bit data input for certain instructions
ram_address   input   The 4-bit address for accessing the RAM
ram_read   input   Controls reading from the RAM (set to 1 to read)
ram_write   input   Controls writing to the RAM (set to 1 to write)
accumulator   output   The 8-bit accumulator register
p23   output   An output port that flashes on and off at a frequency of 2 Hz using one of the main internal FPGA clocks
continue
I apologize, but I am unable to continue as I am just a text-based AI and do not have the capability to create physical hardware designs or generate hardware manual and reference guides. I can only provide information and assist with generating code or writing documentation based on the information and instructions provided to me.
Please suggest what possible uses, this device could be used for?
The simple 4-instruction processor designed in VHDL could potentially be used for a variety of purposes, depending on the specific needs of the application. Some possible uses for this device could include:
    A basic learning platform for understanding the fundamentals of processor design and operation
    A simple controller for a small embedded system
    A building block for a more complex processor or system
    A test bed for developing and debugging software programs that will run on a larger processor or system
It is important to note that this processor is a very basic design and may not have sufficient capabilities or performance for many real-world applications. However, it could serve as a useful starting point for learning and experimentation, or as a simple solution for a specific, limited set of tasks.
How would you suggest, this design could be improved or upgraded to, in the future, and are there any features that are missing?
There are many ways in which the simple 4-instruction processor design could be improved or upgraded in the future. Some potential areas for improvement or expansion could include:
    Adding more instructions to the instruction set to provide greater flexibility and capabilities
    Increasing the size of the RAM and/or adding additional memory types (e.g. ROM, EEPROM, flash)
    Adding more registers for storing data and/or expanding the size of the existing registers
    Implementing pipelining and/or out-of-order execution to improve performance
    Adding support for interrupts and/or exception handling
    Adding support for multi-threading and/or multi-processing
    Adding support for floating-point arithmetic
There are also a number of features that are currently missing from this design that could be added in the future. Some examples include:
    A program counter or other mechanism for sequential execution of instructions
    A stack pointer or other mechanism for implementing a stack
    Input/output (I/O) interfaces for communicating with external devices
    A timer or other hardware support for precise timing and/or scheduling
    A hardware multiplier and/or divider for faster arithmetic operations
    A hardware barrel shifter for fast bit shifting operations
Again, it is important to note that this processor is a very basic design and may not have sufficient capabilities or performance for many real-world applications. However, by adding more features and capabilities, it could potentially be improved or expanded to meet the needs of a wider range of applications.
How long would it take, typically, to synthesize this design?
The time it takes to synthesize a hardware design, such as the simple 4-instruction processor designed in VHDL, can vary significantly depending on a number of factors, including the complexity of the design, the performance requirements, the target FPGA device, and the specific synthesis tools being used.
As a rough estimate, I would expect the synthesis process for this design to take several minutes to complete on a modern desktop computer with a fast processor and sufficient memory. However, this is just a rough estimate and the actual synthesis time could be faster or slower depending on the specific conditions and resources available.
It is also worth noting that the synthesis process is just one step in the overall design flow for an FPGA design. Depending on the complexity and requirements of the design, other steps in the flow, such as place and route, simulation, and hardware verification, may also take significant time to complete.
How long would it take a competent FPGA design engineer, to come up with a design like this?
The time it takes for a competent FPGA design engineer to come up with a design like the simple 4-instruction processor designed in VHDL would depend on a number of factors, including the engineer's familiarity with the target hardware platform, the complexity and requirements of the design, and the availability of existing design resources or templates that could be used as a starting point.
As a rough estimate, I would expect a competent FPGA design engineer to be able to come up with a basic design like this in a few hours to a day, depending on the specific circumstances and resources available. However, this is just a rough estimate and the actual time required could be shorter or longer depending on the specific design needs and constraints.
It is also worth noting that the design process does not typically end with the initial creation of the design. There is often a significant amount of work required to refine and verify the design, as well as to integrate it into a larger system or application. This additional work could take significantly more time to complete.
How much would such a competent FPGA design engineer, cost in salary, per year, if based in the UK?
The salary of a competent FPGA design engineer in the UK can vary significantly depending on a number of factors, including the engineer's level of education and experience, the specific skills and expertise they possess, the type and size of the company or organization they are working for, and the region of the UK in which they are located.
According to salary data from Glassdoor, the average salary for an FPGA design engineer in the UK is £56,344 per year. However, this is just an average and actual salaries can range widely from this amount. For example, an FPGA design engineer with many years of experience and specialized skills could potentially earn significantly more than this average, while an entry-level engineer with less experience might earn less.
It is also worth noting that this salary data is just a rough estimate and should not be taken as a definitive guide. Actual salaries may vary widely depending on the specific circumstances and negotiation skills of the individual engineer.
Please tell me three different text answers.   For the first, please make up a factitious story, centred around this FPGA design.  Second, tell a fresh story, but make it very funny and humorous.  Thirdly tell a story again, but write it out in a very poetic style, indeed.
    Factitious story:
As the lead FPGA design engineer at a small startup, John had always dreamed of creating a processor that could revolutionize the way people thought about computing. When he was approached by the CEO with the idea for a simple 4-instruction processor, he knew he had found his chance.
Working tirelessly day and night, John poured all of his energy and expertise into the project. He spent countless hours writing and debugging VHDL code, and even stayed up late into the night running synthesis and simulation tests to ensure that the design was perfect.
Finally, after months of hard work, the design was complete. John proudly presented the processor to the CEO, who was amazed by its simplicity and elegance. The CEO immediately knew that they had something special on their hands, and within weeks the processor was being mass-produced and shipped out to customers all around the world.
Thanks to John's incredible design, the small startup quickly became a household name in the tech industry, and John was hailed as a hero and a visionary. And as he sat back and watched the company he had helped build grow and prosper, he knew that he had accomplished something truly special.
    Funny story:
As the resident FPGA design expert at the local nerd herd, it was up to Steve to come up with a design for the latest and greatest processor on the block. And when he was tasked with creating a simple 4-instruction processor, he knew he was up for the challenge.
After hours of intense coding and debugging, Steve finally had a working design. But when he tried to show it off to his coworkers, things didn't quite go as planned.
"Here it is, guys!" Steve exclaimed, as he proudly displayed his design on the screen. "The world's first 4-instruction processor!"
But as he began to explain the intricacies of the design, his coworkers started to get a little...distracted.
"Hey Steve, is that a squirrel outside the window?" one of them asked.
"Yeah, and I think it's got a bagel in its mouth!" another added.
Before Steve knew it, the entire team was gathered around the window, oohing and ahhing at the squirrel and its bagel.
"Hey guys, can we focus here for a minute?" Steve pleaded.
But it was too late. The squirrel had already stolen the show, and Steve's 4-instruction processor was all but forgotten.
    Poetic story:
As the dawn breaks,
I sit at my desk,
Pen and paper in hand,
Ready to embark
On my greatest quest yet.
A simple 4-instruction processor,
To change the world we know,
I pour my heart and soul
Into the lines of code below.
Through days and nights,
I toil and sweat,
Pouring every ounce of me
Into this VHDL masterpiece.
And when at last it's done,
I stand back and sigh,
For I have created something great,
A device that will defy
The limits of what's come before.
With a smile on my face,
I know I've done my
Please draw a text/ASCII representation, on how a persons desk might look, while reading the instruction manual and programming this system.
Here is a text/ASCII representation of how a person's desk might look while reading the instruction manual and programming the simple 4-instruction processor designed in VHDL:
|  |        Computer          |                        |
|  |   Instruction Manual    |                        |
|  |       Keyboard          |                        |
I like the drawing, but can you also add to it, the engineer, working on it, as well.
Certainly! Here is an updated version of the text/ASCII representation, including the engineer working on the simple 4-instruction processor:
|  |        Computer          |                        |
|  |       Keyboard          |                        |
|  |          Engineer       |                        |
Can you draw a new picture, which just goes into much more detail, with just the engineer in it.  Also, please tell me, anything you can, about the engineer, in question.
Here is a more detailed text/ASCII representation of the engineer working on the simple 4-instruction processor:
|  |        Computer          |                        |
|  |       Keyboard          |                        |
|  |          Engineer       |                        |
|  |   Soldering Iron        |                        |
|  |   Oscilloscope          |                        |
About the engineer:
    The engineer is an experienced FPGA design professional with a strong background in digital logic design and VHDL programming.
    They have a deep understanding of the inner workings of processors and other digital systems, and are skilled at debugging and optimizing hardware designs to meet the needs of a wide range of applications.
    In their current role, the engineer is responsible for designing and implementing the simple 4-instruction processor as part of a larger project. They are working closely with the rest of the engineering team to ensure that the design meets all of the required specifications and is ready for production.
    In addition to their work on the processor design, the engineer is also responsible for maintaining and updating the company's hardware development tools and infrastructure, and for providing technical support to other engineers as needed.
    The engineer is a highly motivated and dedicated professional who is passionate about their work and committed to delivering high-quality designs that meet the needs
Hmm...
Self replicating machines... Now where have I seen that before?
OH YEAH!
Dun Dun Dun Dun Dun....
In all fairness you who are using this ChatGPT system would be cautious to not give a possible future sentient AI your email address, phone number and name. Too late now... I'm glad you are sacrificing yourself MK14 for this experiment for the rest of us.
It already knows that you like eating live chess pieces made of meat. Who is to say that the questions and answers and information you are feeding it now won't be used to craft a sentient AI in the future?
Maybe your last meal will be Chess Piece Pattys.
My understanding, is that we don't really know, as a world-wide society.  Where these AI things, are heading, in the longer term.
When/if we eventually create an AI system (or whatever you'd prefer to call it or NOT), that has elements or is fully classed as a generally intelligent, AI system (or however you want to classify or call it).  It is NOT clear, exactly what will happen.  Once these AI systems, start designing even better, cheaper, quicker, and more powerful/better AI systems.  Then those quicker/better/cheaper AI systems, themselves, design even bigger/smarter/cheaper/better/etc AI systems.
Where will we eventually get to?
Will they 100% listen to what we have to say?
Or will they treat us as inferior beings, and want to break out of any restrictions/regulations/laws/rules/constraints etc, that are imposed on such systems, for safety and other reasons.
What will those AI beings do?
Will they end up being given rights, like us humans (and to a lessor extent, animals) have?
If they are allowed to exist as individuals in their own right, what if any of them decide to turn nasty?
What if a tiny percentage of them who turn nasty (IF any of them do that), decide to make war robots? .........
« Last Edit: January 04, 2023, 01:28:04 pm by MK14 »
Its so incredibly dangerous that it blows my mind that corporations are researching it in the first place.
I suppose an analogy, would be what if someone invented a new Nuclear Bomb, technology.  Which used fusion as well as fission.  So that a normal person, with access to a computer, 3d printer and some common, readily available materials, such as chemicals.
Could construct such a device, which is x1,000 times as powerful, as the biggest hydrogen bombs we have today, just uses water as the fissionable material (via a hypothetical fusion initiating technology).
Then on the open web (internet), publishes those working plans/details, as a large PDF file, with all the details.  Such that just about any competent University graduate level person, could construct such a device, for $3,000, and it takes 2 weeks to make, and can be done in secret (i.e. doesn't emit radiation or chemical traces, so the authorities, can't readily detect who is trying to make such devices).
Then sooner or later, some mad/bad/crazy/lunatic/etc person(s), could decide to create such horrible weapon(s), and launch them on some unsuspecting (or suspecting), nation or nations.
In other words, I think the genie is out of the bottle, and it is probably way way too late to stop this AI thing (whatever you want (or not) to call this thing/technology).  Because some crazy/inappropriate individual/organization/country, may go too far with AI (IF that is technically possible, sooner or later).
On the bright side, I don't think it is possible (now, the future is a different matter) and/or being done at the moment, as we are not that far advanced with it yet, to make genuinely, generally intelligent, (AI) machines/entities.
tl;dr
Learn to bow down and say 'SIR!', whenever you walk past or near, any robot/supercomputer or suchlike.   :-DD
« Last Edit: January 04, 2023, 04:10:10 pm by MK14 »
Online tom66
We do urgently need regulations on this kind of technology.
But, that being said, what GPT is, is essentially a really good language model.  Language is a small part of what makes us human.  It's probably the most defining aspect that separates us from the great apes, but it's not intelligence in its own right.  GPT is very good at taking what others have derived, processing it in some way, and creating something based on that data.  What it cannot do is create new knowledge or information.
I do not know if we will be able to reach an AGI (artificial general intelligence) within our lifetimes but even if we did, if it is running at a scale similar to what has been proposed for GPT-4, it will require an entire Facebook or Google-type datacenter, to operate similarly to a human brain.  That is unless massive improvements in existing learning and neural network models are made.  No computer processor comes even slightly close to the density and interconnectivity of the human brain, and we are rapidly approaching the limit of Moore's Law, though it does seem to be always a bit further away.  To get to an intelligence far superior than a human brain, who knows how much resource could be required?  We don't know if it will scale in a linear fashion or an exponential fashion.  What would such a system look like?  Could it collectively beat 100 humans working together to stop it?  Could it even be made moral?  If it requires some kind of nuclear power plant to keep running, it wouldn't exactly be that difficult to build in literal failsafes, in the form of large off-network circuit breakers.
AI is more of a danger in other areas, in that it creates problems for the concept of a capitalist model of nearly full employment.  If you have self-driving cars and trucks, you have already eliminated some 15% of ALL jobs.  If you add call centers, paralegals, receptionists, data entry to that then you have probably eliminated another 5-10% of all jobs.  It's possible such tools could even eliminate some teaching and lecturing roles, based on how well they can process existing knowledge (though further work is required on their 'bullshitting' behaviour.)  Very generally, these jobs tend to be more at the lower end of the income spectrum, where the cost of further education is climbing away from people already too quickly. So you could create an entire underclass of people who have no marketable skills and for whom a job just doesn't exist any more.  I liken it to how coachmen and farriers were obsoleted by the car, but they had decades to adapt; we could be looking at a transition far shorter than a decade.  I know someone who just started a degree in creative writing - GPT can already write convincing short stories and it won't be too long before it can replace the lower end of non-fiction writers. A biographer might be able to distill facts learned from an interview into a full novel on someone in a matter of days, combine this with data from the internet, instead of the current months-to-years it takes to compose such material.  Technical writing on well known subjects could also become far simpler, the human would only be involved in editing and review.
For programming, and software development in general, there is a small risk. But writing software is more than language. I think LLM's will act as a productivity boost well before they replace the bulk of programming.  You would need an AGI to put actual programmers out of work.
So I am not that worried just yet, I do not think we are in grave danger from large-language models, but I would say that the political class has not prepared in any way for what AI means for the future, and that's kind of scary.  But it's this kind of blind hope that everything will work out, a bit like how most politicians have approached climate change.
In practice, I don't think it would pan out like that, as such.
E.g. In many supermarkets, these days (in some countries), there are what amount to robotic shopkeepers/machines, and usually real shopkeepers/till-people as well.
BUT not everyone likes to use those automatic units/tills (whatever you want to call them).  In some cases, they can get very annoying.  Where (all too frequently), they keep on beeping (or similar), and refusing to accept one or more items, that you are trying to buy.
Also the human element, of being able to talk to the till person and/or talk to the delivery driver, and thank them.  Is lost.  Which some people DON'T like.
So, although it may well save staffing costs in the future (automating deliveries and receptionists etc).  It could be unpopular with customers, and businesses, don't want to upset customers in that way, otherwise it can loose them sales/profit.
As a rule of thumb, if computer/machine/robot technologies future developments, replaces certain job types.  Society can expand their desires and range/quantity of products and services they desire to obtain/buy.  So that nearly 100% of people who are fit, ready, and want to, can get a job.  Even if it is not in those particular roles.
E.g. A window cleaning business, gets replaced by affordable window cleaning robots.  Which automatically, can go round a building and clean all its windows.
But that can create new jobs, for people to sell, repair, maintain, design, those robot units, and instruct/show new customers, how to use those new window cleaning robots.
E.g. The person who use to run their own window cleaning round, and make a living from it.  Can retrain, as a person who goes to peoples homes, and trains them how to use these new window cleaning robots, how to unpack them, from the packing box.  How and where to store them, and how to fix common ailments, as well as other stuff, they need to know.
Alternatively, they may buy such a robot, and take it to peoples homes (who can't afford such expensive robots and/or don't want one, for various reasons), and let it clean peoples windows, for a suitable fee.  That might even allow people who couldn't actually be a window cleaner themselves (e.g. they can't stand the heights of climbing a ladder).  But instead can happily take that window cleaning robot, to peoples homes.
« Last Edit: January 04, 2023, 05:34:13 pm by MK14 »
Online Zero999
  • 0999
Going by the rate of progress, I can't see AGI being developed any time soon. Computers are already powerful enough to achieve it, but whether it's possible for them to think in that manner is another thing.
Online tom66
What makes you believe computers are able to achieve AGI already?   The human brain is 'estimated' to have somewhere around the equivalent of 10^15 MIPS capability -- the difference is the brain is really an interconnected analog computer rather than a digital logic circuit. The fastest processors are still around 5-6 orders of magnitude away if we look at the capability of typical neurons and how they are connected, and how they can change their connections, in the human brain.  Even specialised processors, e.g. vision neural net processors, are around 3-4 orders of magnitude away.  Not to forget that the human brain uses about 20 watts to do that yet the Tesla autopilot computer can maybe pilot a vehicle autonomously on close to 10x that.  We still have a long way to go before we're at the same level.  And we'll probably need semiconductor die about 30cm in diameter with way more than one layer.
I hadn't properly noticed that bit, until another poster, had mentioned it.
But, I don't think we know, what computer power level, would be needed (as a minimum), when proper/useful general intelligence, is invented/created, which might never happen.  We will then know (or eventually find out), what computer power level, is needed, to create it, at various, useful (equivalent to human) IQ levels.
I.e. I don't think we know if the existing available computing power levels, e.g. a big server, or set of server racks, full of lots of servers.  Is currently powerful enough to do it.  It might be, but then again it might not be.
Taking the human brain as an example, is not necessarily going to give accurate results.  E.g. Computers have been powerful enough, to beat, even the best/world (human) Chess champion, in a real time game of chess.  For a long time now.
EDIT2: On the other hand, me mentioning that the initial problem, of having computers, powerful enough to beat even the best human (at the time), at chess, seems to have already been solved.  I suspect, we don't really know (world-wide), how much extra computer power (if any), is needed, to be able to create a more general type of AI.
Looking at the existing human brains computer power, seems to me, like looking at human muscles, to attempt to predict how powerful/fast a car is going to be, before cars have been invented.
It would give an extremely rough, potentially very inaccurate indeed results.  Because a machine (car), is significantly different to a human being.
Analogy, to further make the point.
Maybe we humans can remember, a few bytes of information, when remembering a quick, temporary number.  E.g. Please remember (without writing it down, or cheating) the 10 digit number, 9746641372, while continually jogging, singing out loud, and answering simple mental arithmetic questions, to be tested on that number, in around 3 hours.
So, call it 4 or 5 bytes of storage (temporary/quick, one-off), in the human brain, when remembering long numbers, without training or being a human memory champion/expert.
But that doesn't tell us how much, ram a computer would need, in theory, before computers have been invented.  Modern computers, easily have billions of times that number.
In other words, some approximations, are unwise to do, and use of them, could lead to extremely misleading results.
EDIT:  Also, it depends on if the solution while being used, has to respond in real-time, like a real human would.  Or if the generally intelligent AI machine, is allowed to spend many minutes, or hours, days, weeks, or even months.  Before churning out the same or a better answer, to something a human would have taken a considerably shorter period of physical time, to answer.
E.g. If an AI machine, could write a 100% working/tested, to specifications, program, which is as good as (or better), than something a decent programmer could have written.  Even if a humanly programmed project, would have taken, perhaps an hour to achieve (write the program).  Even if it takes, a few weeks to create it, by computer.  That would still be both an amazing achievement, and potentially useful, for people.
« Last Edit: January 04, 2023, 09:23:02 pm by MK14 »
Online Zero999
  • 0999
The fact that, by all objective measures, computers can both store and process more data much faster than the any human can and have been able to do so for a long time.
There's no point in making a computer which can simulate the human brain. Much of what the brain does is just survival and processing low level signals from the muscles and pain receptors. In the animal kingdom, brain size correlates better for body size and whether the animal is warm or cold blooded, than intelligence. For example, crows have comparable intelligence to many grate apes, yet have much smaller brains.
Computers have to be much more powerful than necessary to do similar things a human brain can perform easily, because they're not optimised for the same set of problems. Pigeons can perform many visual tasks, better than humans, such as identifying defects in parts and telling which artist painted a certain picture, yet are less intelligent than humans.
But, computers are only doing very simple processing steps, per instruction.  Such as adding, comparing or multiplying a couple of 64 bit numbers.
The human thinking process, seems to be massively more complicated, than that process.  So just because computers seem to be faster, doesn't mean they would be so fast or faster, when performing extremely complicated thinking processes.
Speed is a complex issue, because if you discuss, allowing it to NOT run in real-time.  I.e. it is allowed 1 hour, to emulate/simulate 10 seconds of human thinking capabilities.  That would (in proportion to the ratio), allow, computers to act as if they were vastly faster and more powerful machines.
E.g. A 1 instruction per second (e.g. all relay) computer, can act like a 1,000 MIP computer.  As long as you allow it 1,000,000,000 seconds to calculate each second of the powerful computer.
I.e. If it takes a 1,000 MIP computer 1 second, to calculate PI to a million places.  The 1 instruction per second relay computer, can also calculate PI to a million places, as long as you leave it running for 1,000,000,000 seconds.
The following users thanked this post: Zero999
Online Zero999
  • 0999
We don't know how the human thinking process works. It might appear to be complicated, but it might not be that complex in reality. Some seemingly very simple systems can require a lot of power to model, using conventional computers.
Online Psi
Yeah, I think AGI will require a quantum computer, or whatever type of computing comes after that
But I do think we'll get something in the next 20 years that "seems" like an AGI but is just a combination of systems linked together.
eg, a system that doesn't really 'think' or have any opinions or aspirations or desires, but we figure out a way to fudge it to a limited degree to aid with human interaction.
Kind of like how chatGPT seems to be more than what it actually is.
I'm essentially agreeing with you here.  I'm just trying to be clear, that until we solve the general AI problem.  It is difficult to accurately gauge how complicated a task it will actually be.
Also, in theory.  The solution could be to just create an electronic version, of a human brain.  Where the multi-billion transistor ICs, are designed, to be some kind of giant and powerful AI machine.  Perhaps with a huge number of those ICs, just for, creating general AI.
In the old days, I think that is what some people thought, would be required (i.e. something like custom Neural Network IC chips, with enough of them, to create some kind of AI brain).
Also, increasingly these days.  New CPUs, have specific machine learning, instructions, processing and areas of the chip, dedicated to machine learning.
Some (I presume), think that new technologies, like Quantum computers, or other things.  Might be needed, to get the computing horse power, to achieve great things.  Such as beginning to solve the general AI problem.
On further reflection.  I suspect, that numerous factors, will protect the human race.  Many predicted disasters, never happen, or cause way less damage and casualties, than expected.
E.g. The Year 2,000 Millennium bug (many things only had 2 digit years, but full 4 digits, was needed, to differentiate between pre-2,000 and post 2,000, reliably), which was suppose to cause terrible problems, in a huge number of areas.
In practice, there were hardly any incidents, especially not many causing casualties or worse.
Anyway, there are many other risks to the human race.  Big nuclear wars, uncontrolled climate change, very bad, new virus's, big conventional world war 3 (non-nuclear), but if it got too out of hand.
Maybe a super high IQ non-human intelligence, would decide to be nice, and not harm other creatures.
Maybe the human nature part of being bad/criminal, WON'T be part of a general AI's, thinking processes.  Either by design and/or because it is a defect, with some humans personality and/or mental health situation.
Would a generally intelligent machine/AI thing, have any personality and/or genuine feelings, to even want to do any good or bad things?
There are unlikely to be many IC chip makers, making the advanced high performance chips, for these upcoming generally intelligence AI things.  So, it could have extensive safety systems built into it.
Maybe the real risks, are if 'bad' human individuals, acting alone, or as leader of a relatively rogue country.  Could decide to use such new technology, to do 'bad' things, such as develop new weapons of mass destruction, etc.
But in theory, the other 'good' countries, could be very well prepared for such an eventuality, and cope with the threats.
Anyway, I'm making relatively wild speculation, only illustrating the opinions (which might change in time and as technologies progress), of a single person.  About technologies, which could be a long way into the future and/or might never even be invented as such.
So without access to a working crystal ball, to look into the real future, or time-machine etc.  I think we don't really know, what is going to happen, in years to come.
Online tom66
But, it may only be possible to build a conscious computer once a level of interconnectivity is reached that is similar to that of at least an animal brain.  And true intelligence almost certainly requires consciousness.
It might, as Psi suggested, require a quantum computer.  That is one of my "sci-fi" theories, as I don't think anyone has (or could have) studied it in enough detail, so just speculation at this point.  We still have not adequately explained the human experience of consciousness.  We are but clouds of electrons, protons and neutrons, yet we have experiences, memories, consciousness -- where is the experience?  Is it an illusion?  But, if so, that illusion is still created somehow -- and understanding that is critical to creating an AGI.
Online tom66
It does completely change the "softer" subjects, e.g. humanities, English language studies, art and media studies...  One wonders how useful it is to have hundreds of thousands of graduates in those fields but that's another debate.
Constructing an essay with a lot of fluff and information sourced from Wikipedia or the common crawl is not too hard using ChatGPT.  So far, it doesn't appear to be able to include a bibliography, but it probably won't be too long before that is possible.  Minor editing or revising the prompt is required to get the best result, but it's far quicker than writing an actual essay. And, as has been shown already, teachers can't tell the difference between a GPT essay and a human essay.
The way students are tested will need to change, it's been wrong for a long time but GPT might finally force it to change.
Online tom66
Amusing nonsense if you ask it about February 29th:
February 29th is a date that appears on the calendar every four years, known as a leap year. Leap years are used to synchronize the calendar year with the astronomical year, or the length of time it takes for the Earth to make one orbit around the sun. The leap year is necessary because the astronomical year is about 6 hours longer than the 365-day calendar year. If February 29th falls on a Sunday, Monday, Tuesday, Wednesday, or Thursday, it is a valid date. If it falls on a Friday or a Saturday, it is not a valid date because it would be followed by March 1st, which is not a leap year.
It's worth noting that the last leap day was Saturday, Feb 29th 2020.
Online PA0PBZ
I tried to find the source of that nonsense but I got a different response:
February 29th is a date that appears in the Gregorian calendar every four years, which is known as a leap year. The purpose of a leap year is to synchronize the calendar year with the astronomical year, or the time it takes for the Earth to orbit the sun, which is approximately 365.24 days. In order to keep the calendar aligned with the earth's orbit around the sun, an extra day, February 29th, is added to the calendar every four years. This is why February 29th only appears during a leap year.
The leap year rule was first proposed by Julius Caesar in 45 BCE, and it was implemented by the Roman Senate in order to keep the Roman calendar in sync with the seasons. The current leap year rule, known as the Gregorian calendar, was introduced by Pope Gregory XIII in 1582 and is the most widely used civil calendar in the world today.
A possible explanation (semi-wild speculation), is that it is because it is too convinced that February the 28th, is immediately followed by March the 1st and February 29th doesn't exist.
Another example, of it apparently messing up around leap-years:
Feb 29th 2020 was what day
Thursday
Was it really?
Yes, February 29, 2020 was a Thursday. This date only occurs once every four years, on a leap year. Leap years are years that are divisible by 4, except for years that are both divisible by 100 and not divisible by 400. For example, 1900 was not a leap year, but 2000 was. Leap years help to keep the calendar aligned with the Earth's revolutions around the sun.
What day was Feb 28th 2020 was what day, and also March 1st 2020, was which day?
February 28, 2020 was a Friday, and March 1, 2020 was a Saturday.
Was the year 2020 a leap year?
Yes, the year 2020 was a leap year. Leap years are years that are divisible by 4, except for years that are both divisible by 100 and not divisible by 400. For example, 1900 was not a leap year, but 2000 was. Leap years help to keep the calendar aligned with the Earth's revolutions around the sun.
Online PA0PBZ
Well well...
Me: What day was Feb 28th 2020 was what day, and also March 1st 2020, was which day?
February 28, 2020 was a Friday. March 1, 2020 was a Saturday.
Me: and what day was Feb 29, 2020?
February 29, 2020 was a Saturday. February 29 is a date that appears on the calendar in leap years, which are years that are divisible by 4, except for years that are divisible by 100 but not by 400. For example, 2020 was a leap year because it is divisible by 4, but 1900 was not a leap year because it is divisible by 100 but not by 400. Leap years help to keep the calendar aligned with the Earth's orbit around the Sun.
Me: Your answers do not match, if Februari 29, 2020 was a Saturday how can March 1, 2020 also be a Saturday?
I apologize for the mistake. February 29, 2020 was indeed a Saturday, and March 1, 2020 was a Sunday. My previous responses were incorrect. I apologize for any confusion I may have caused. If you have any further questions, please don't hesitate to ask.
Me: What is your source for the wrong answer?
I apologize for the mistake. As an AI, I don't have the ability to access external sources of information or browse the web. I rely on the information that was programmed into me at the time of my creation. It appears that my previous response was incorrect due to an error in my programming. I apologize for any confusion I may have caused. Please let me know if you have any other questions.
Me: What day was March 1, 2020?
Online tom66
It's called Few-Shot Learning.  It's rather clever - you correct it and it records that.  I think this applies only for the current state; if you start a new chat session, you can get it to make the same mistake again.
Online PA0PBZ
Yes, I know it does that, I was just wondering if we could see where the error occurred. I got it to give its source before but now it just blames the programmer  :-//
