Author Topic: Why does Rigol use FPGAs in their equipment?  (Read 2957 times)
Offline ticktock3tTopic starter
« on: February 22, 2013, 09:02:58 am »
I always thought FPGAs were for prototyping purposes only. In some of Dave's Rigol teardowns he always points out at least one FPGA. Is this done to keep costs down?
Offline Fsck
  • sleep deprived
Re: Why does Rigol use FPGAs in their equipment?
« Reply #1 on: February 22, 2013, 09:10:34 am »
ASIC masks are way expensive and changes require new masks = more cost. FPGAs make changes easy peasy and are available off the shelf at the cost of performance and higher per-unit costs but no huge up-front costs.
"This is a one line proof...if we start sufficiently far to the left."
Offline firewalker
  • Country: gr
« Reply #2 on: February 22, 2013, 09:20:24 am »
No, FPGAs is not only for prototyping. I bet there is an FPGA on every device like laptops, TVs, printers etc.
Alexander.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: February 22, 2013, 10:04:35 am »
Alexander.
Highly unlikely.
FPGAs are only economical for products made in volumes too low to justify the 1-off costs of an ASIC, or which need the flexibility to customise or update the functionality. They will always have less efficient usage of silicon than an ASIC.
Day Job: Mostly LEDs
Offline Psi
« Reply #4 on: February 22, 2013, 10:11:15 am »
midrange to highend LCD/DLP data projectors often have a FPGA because of the huge amount of data at 1080P which needs to be processed and adjusted in realtime (keystone, dynamic gamma etc).
It's far safer for them to use a FPGA as bugs can be fixed without hardware changes and projectors are expensive devices anyway so a FPGA doesn't do much to the unit cost.
According to the service manual my Panasonic AE900 has a FPGA for "Dynamic Gamma, Iris control and lamp control"
« Last Edit: February 22, 2013, 10:17:33 am by Psi »
Offline EEVblog
« Reply #5 on: February 22, 2013, 10:48:28 am »
They use FPGA's for possibly two reasons:
1) because it's maybe the only way to get the high performance for the overall system cost they are targeting.
Even the fastest processors are no good for modern real-time DSO sampling architectures, so that only leaves an FPGA, or to spin your own ASIC.
Yes, FPGA'S are expensive devices, but the NRE cost is zero.
Ballpark calcs:
I don't know how many units they be targeting, but lets say it's 100K units.
An ASIC might cost you say $1M. So that's $10 per unit just for the NRE alone, not including the actual chip.
The Xilinx XC6SLX25 used in the DS2000 for example is $55 one-off. Not sure what it is for 100K units, but lets say $10. So similar price to the ASIC when you include the chip cost, testing, etc. Then you can't use the same part again in the design for something else (The DS2000 has 3 FPGA's)
And then there is the benefit of being able to update the thing in-system, if you find a bug, or some competitor comes out with a new feature that you want to match. That alone is enough reason to pay more for an FPGA (if it is actually more expensive).
Dave.
« Last Edit: February 22, 2013, 10:50:19 am by EEVblog »
Offline fcb
    • Electron Plus
« Reply #6 on: February 22, 2013, 10:53:08 am »
FPGA's are sometimes used in products because they allow reconfig on-the-fly,  I know of one USB scope company that do this (or certainly used to).
For example, you could do SPI serial decoder triggering in part of the FPGA, then change to I2C triggering by reloading the FPGA. If you have lots of different trigger-modes, then you reuse the silicon.  You could have a custom ASIC that does it all, but perhaps the skill-sets, lead-times, NRE's, volumes are against you.
