Author Topic: OpenPNP and other stuff server requirement  (Read 949 times)
Online blueskull
  • Country: cn
  • Power Electronics Guy
« on: September 02, 2018, 06:31:02 pm »
Hi gurus here,
I'm looking for a computer that can do the following things as a home server:
1. Control an OpenPNP-based PnP machine (OpenPlacer) with 2 cameras,
2. Control a GRBL-based CNC (Carbide 3D Nomad 883 Pro),
3. Serve files from a relatively slow HDD array (software RAID 1, up to 200MB/s) over Windows file sharing,
4. SMB also shares a Canon printer,
5. Run a Brother scanner,
6. Stream desktop to another computer over RDP remote connection.
What kind of hardware should I need?
Here are two candidates that I have:
1. Intel NUC with Haswell i3, 8GB RAM, 256GB SSD
2. Intel NUC with Kabylake i5, 16GB RAM, 512GB SSD
I have both, but I want to sell one for some cash. Since I don't have OpenPlacer set up already, I can test out for real.
The second one has a 28W CPU that's more powerful than most high end Ultrabooks, so I have no doubt for it.
However, I prefer to use the first one since I can't really sell the first one for any reasonable amount of money, so I prefer to get rid of the second one.
OpenPNP knowledge is much appreciated from PnP gurus here.
Offline Halcyon
  • Global Moderator
Re: OpenPNP and other stuff server requirement
« Reply #1 on: September 03, 2018, 03:48:21 am »
What you want to achieve is relatively low-end stuff. They don't take a lot of computing resources at all (even all at the same time).
Your i3 NUC would do the job fine, but I guess it depends on how desperate you are for the money? I'd keep i5 NUC for myself and sell the older one but as you've already stated, you already have a preference so go with that.
Although, if at all possible, avoid Windows 10, it's complete garbage. I actually find it slower than Windows 7 in many ways.
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: September 03, 2018, 12:46:23 pm »
Does OpenPlacer actually use the cameras for machine vision during operation? That can be quite GPU intensive.
Online blueskull
  • Country: cn
« Reply #3 on: September 03, 2018, 12:56:34 pm »
Machine vision and RDP is all what I'm concerned about. Keep in mind the i3 is a 15W SKU without turbo boosting.
I'm not really desperate in cash. I just bought a maxed out X1 Carbon, and I just want to consolidate my computers and liquidate the excess.
Forgive me if I'm too outdated, but last time I used OpenCV (back in 2014), it didn't support GPU well.
Offline NiHaoMike
    • Facebook Page
« Reply #4 on: September 03, 2018, 01:08:44 pm »
It has improved by a lot. In mid 2017, I worked on a test setup that used GTX 580s (what they had lying around) as part of a machine vision system for automated testing.
https://opencv.org/platforms/cuda.html
