I personally don't like these bulbs.
The only application where I like them is in that golden glass colored retro big bulbs for 1930s retro applications.
For new LED lighting I never would choose:
- HV (110-230V) leds
- E27 bulb replacements (GU10 is ok'ish).
I don't get it if you really really want a lightbulb with its orange glow when dimmed than buy a lightbulb not a ledreplacement.
Or better get in the led century: design your lighting conditions with multiple different lightsources and choose the settings (scenes) for the application, meaning if you have a dinnertable where you study and also like to eat in a romantic atmosphere you need more different lightsources with different colortemperatures and lumens to choose from. With for instance the modern tunable white color led bulbs you can do anything your creativity can imagine.
These filaments is like when in the late 19th century they designed automobiles to replace the horses, they would have put an engine in an iron horse and let it run with four robotised legs instead of integrating it in the carriage. This is so....... not getting what led could do, or just unable to change and stick to what you knew.
Take a look at modern light led fixtures, they are pieces of art and have a magnificent lighting pattern.
Yes you have to replace them after 25 years unless you are an electronic engineer and can replace the leds
Throw out your old E27 fixtures (unless they are design and worth considerable amount of money) and join the new century of lighting
