I was out today so I bought a couple new types of LED filament bulbs to play with, both are Ecosmart brand from Home Depot and both claim 800 lumens. One is a 6.5W clear bulb in a compact envelope the size of a standard appliance bulb, if the ratings are believed that's a very impressive 123 lm/W. The other is a more conventional A19 size, inside frosted so it looks exactly like an ordinary incandescent bulb, it's 7.5W so slightly less efficient, likely owing to the diffuse coating. Both have a reasonably nice 2700k light, CRI is nothing spectacular, probably around 80. They run cool and put out a lot of light, and to a casual observer they look incandescent, they even dim quite nicely on a dimmer.
There is one fatal flat though for me that will restrict these to specific uses, they flicker. My other half can't see the flicker at all but it's very visible to me, especially if I scan my eyes across the room looking from one thing to another or move my hand. I suspect it's unavoidable unless we have some kind of breakthrough in compact capacitors in high enough ratings that will fit down inside the base. That right there is probably why they remain somewhat of a niche product.
