My go to tips for rework are STTC-199 for drag soldering and little stuf STTC-117 for larger bits and switches and such, and SMTC-162 for multi pins at one time like desoldering headers and such. For assembly I use a weller WTCP and have for over 30 years. Some people don't like that iron, particularly hakko fanboys, but it is the best through hole iron ever created for high volume pcb assembly with proper heat flow and capacity characteristics. Its only real fault is the magnestat in the handpiece goes out after a few years of heavy use. Small price to pay for the savings from the long tip life. The Metcal is a terrible iron for assembly because of its wake/sleep hysterisis cycle. Half the joints are cold because it is either going into or out of sleep/tip saving mode. It makes rework possible though because of the specialty tips. For that, and you will notice its marketed as a rework station, its perfect. For the weller our shop standard is the We use the weller PTBB8 and PTAA8 tips
