Author Topic: Why Nobody Buys Sound Cards Anymore  (Read 11613 times)
Offline Homer J SimpsonTopic starter
« on: October 26, 2018, 11:07:40 pm »
Offline nctnico
Re: Why Nobody Buys Sound Cards Anymore
« Reply #1 on: October 26, 2018, 11:24:54 pm »
One of the reasons is that a new version of Windows required to replace the soundcard because the drivers no longer worked. I used to have a whole stack of perfectly fine soundcards but they didn't work with newer Windows versions. People got fed up with that too. Having an on-board audio chip which just works is so much easier.
Linux is kinda the other way around BTW. In my current PC I have a Soundblaster 128 (IIRC) PCI sound card because the on-board soundcard doesn't work. Go figure.
« Last Edit: October 26, 2018, 11:34:18 pm by nctnico »
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: October 26, 2018, 11:37:56 pm »
There's also HDMI for lossless surround, which every modern GPU supports.
Offline rdl
« Reply #3 on: October 26, 2018, 11:57:16 pm »
Those cheap onboard Realtek chips actually don't sound all that great for music, assuming the rest of your set up is halfway good (amp, speakers, etc.) but he's right that they work fine for games, youtube, movies and such. I've got an Audioquest Dragonfly that plugs into a USB port, no drivers required. It sounds as good as the CD player I was using for music before. I'm no audiophool though, I bought it used for $45.
Offline @rt
« Reply #4 on: October 27, 2018, 04:55:03 am »
We have external USB DACs with amp if needed.. much easier.
Offline EEVblog
« Reply #5 on: October 27, 2018, 06:04:53 am »
He coined the name gmail, nice.
Yeah, those sound card makers didn't see the cheap chip motherboard solution coming, doh.
Offline Halcyon
  • Global Moderator
« Reply #6 on: October 27, 2018, 06:18:40 am »
Balanced audio is the way to go. Decent quality internal and external USB sound devices aren't expensive, but the difference between a balance and unbalanced signal is phenomenal.
There is also something about the satisfying click of an XLR cable and connector.
Online JPortici
« Reply #7 on: October 27, 2018, 08:13:40 am »
the cheap integrated realtek chips are 100% perfectly fine. They're going to drive crappy speakers or crappy headphones anyway.
If one is concerned about quality there are audio interfaces for recording that starts at 50€ that at worst are on par with whatever comes for the consumer marked
Offline MrMobodies
« Reply #8 on: October 27, 2018, 10:09:52 am »
I do but I get old stuff.
When I was about 12 I use to go down bootsales and pick up all different ISA sound cards and test them and they all sounded different.
There was one of them which was an Aztech 2320 and what is unique about it is that it has got a hardware sound effect SRS3D. I didn't want know what it mean't at the time but I can hear the instruments and background stuff brought to the top and I can hear so much more detail. I noticed it appearing on Windows Media Player 7 as a plugin but it didn't sound as clear and was distorted on comparison. I saw a Wikipedia article about it some years after and it stands for "Sound Retrieval System".
I have kept a lot of my old stuff to operate them just loop audio through the line in around the house which has been going for nearly 20 years on a Gigabyte 6BXE under my desk and similar and I have others lying around for spares and other with sounds cards for a midi keyboard like a Yamaha SW1000XG .
A lot of power wasted over my audio foolery desires and expectations.
I got the cables cheap as end of line things I would never pay a lot for them brand new.
I wanted to buy one of those ISA to USB bridge and run it under a virtual machine but it was costly to get here.
They announced a release a Wow3d thing but I never saw it selling so I stuck with that.
Recently I also got some Belkin Network USB hubs cheap off Ebay and Creative USB Live sound cards, 8 for £2 each all with the cables and remotes which work quite well without delay or interruption over the network and two go into an Emu 1820m dock and into one of the Aztechs and in a Philips HD1502 headphone base in the attic. I can play off any laptop and it works well over the Wifi access points to my wireless headphones.
Here is one of them I take around to demonstrate.
Bottom ISA card Aztech 2320. It has got a 28k Rockwell modem on it that you could make calls on it back in 1997.
Nobody believes me until I show them the difference through that particular sound card.
« Last Edit: October 27, 2018, 11:44:29 am by MrMobodies »
Offline Richard Crowley
  • KJ7YLK
« Reply #9 on: October 27, 2018, 03:34:48 pm »
Wow. This is the kind of drivel that gives YouTube the reputation of a giant cauldron of misinformation and silly babbling.   :--   :-DD
Online JPortici
« Reply #10 on: October 28, 2018, 07:31:49 am »
PCIe still exist in the form of thunderbolt for high resolution, high samplerate, high channel count interfaces
Offline rjp
« Reply #11 on: October 28, 2018, 07:35:44 am »
good  enough and relatively free is the enemy of excellent and expensive.
ditto smartphones killing so many standalone devices, from music players to cameras and gps units and games consoles and and
Offline daqq
  • Country: sk
    • My site
« Reply #12 on: October 28, 2018, 07:56:24 am »
You make it sound like a bad thing. I'm quite happy not having to drag around:
- cell phone as phone
- camera
- calculator
- music player
- PDA as an organizer and misc
- GPS for GPS
- misc.
as separate devices. And 'good enough', well, most of the time I do not need some really obscure functionality that is only available on a dedicated GPS unit, I just need to know which way to the nearest something. And when I need to take high quality pictures, I'm OK with bringing a camera with real optics. And if you are in a situation where you need sound quality that you can't achieve by a smart phone and would actually notice the difference, then you are not in an outside environment, which kinda defeats the point of wanting a portable music player in the first place.
The following users thanked this post: sokoloff
Offline rjp
« Reply #13 on: October 28, 2018, 08:07:37 am »
- camera
- calculator
- music player
- GPS for GPS
- misc.
I actually offer no   value judgement :) just stating the obvious really.
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #14 on: October 28, 2018, 09:00:20 am »
Actually there is a bit of feedback going on:
* iPod Touch, the last remaining device under the portable media player brand iPod, is an iPhone sans the cellular modem. (If I recalled it right, one early model iPod Touch flat out used the iPhone logic board as-is without the 3G modem installed, and the connector footprint for the 3G modem is clearly visible.)
* Nintendo Switch, likely the first 9th generation game console, is based on the same Tegra chipset as used in some smartphones.
* A lot of consumer cameras now comes with Android for wireless connectivity and image enhancement applications - almost as if it is a smartphone with cellular modem removed and camera module beefed up.
* The TI Nspire series graphing calculators uses their OMAP processor, as used in some early Android devices.
etc.
Offline Lord of nothing
  • Country: at
« Reply #15 on: October 28, 2018, 09:18:37 am »
When I see what many User buy for a Crap Headphone I dont wonder why the cant hear the difference.
Made in Japan, destroyed in Sulz im Wienerwald.
Offline MrMobodies
« Reply #16 on: October 28, 2018, 09:36:30 am »
What I have noticed about wireless headphones FM and digital is that many of them cut out on low volumes and when I turn up the volume they cut out at a slightly higher volume and I had to keep returning them. The FM ones are terrible when they cut out as they give white noise and hurts me ears.
It didn't do it on the Philips HD1502 I got imported from Germany ten years ago and I have been using it since.
It has even got a transmit button on the display for when it does cut out.
The quality seems okay but I wouldn't say it is anything great as it sounds a little hissy with certain playback but then I can adjust the bass and treble on the headphones.
Also the rechargeable AA'S can be pulled out on the side of the headphones without taking them off and I don't bother charge them on the station when I got a bank of them sitting in the chargers. I got two of those old Conrad Charge Manager 2020, one for aa's and one for aaa's waiting for all sorts of things so I don't have to wait when I want some round cell batteries.
« Last Edit: October 28, 2018, 09:39:20 am by MrMobodies »
Offline NiHaoMike
    • Facebook Page
« Reply #17 on: October 28, 2018, 01:11:43 pm »
The digital output works perfectly fine as it's just data. It is still subject to the limitation of no lossless surround, which is what HDMI addresses. There are no HDMI output sound cards on the market since that function is built into every modern GPU, but what seems to be missing is a USB to HDMI sound card. I suppose a Pi Zero could be programmed to work as one...
There was a time when gamers were all against USB sound cards, but that seems to have changed with USB 2.0 sound cards appearing on the market. Also smartphones have gone USB-C which dramatically increased the demand for single chip USB DACs.
Offline tooki
« Reply #18 on: October 28, 2018, 02:07:18 pm »
No, they’re totally different boards to accommodate the different form factor of the case. Tons of shared components of course.
Offline The Soulman
  • The sky is the limit!
« Reply #19 on: October 28, 2018, 02:21:37 pm »
There shouldn't be a audible difference between balanced and unbalanced for short cable runs (i.e. 99% of all consumer applications).
Yes, the click of a proper xlr connection can be satisfying.
Offline Jan Audio
« Reply #20 on: October 28, 2018, 03:56:40 pm »
For professional audio gear there are cards with more ins & outs.
Now a days there are table mixers that are a soundcard, multichannel audio via USB into your "analog" mixer.
Throw away all your old soundcards with each new windows ?
Its getting more standard now so maybe you wont have to throw away so much no more.
  • Country: at
« Reply #21 on: October 28, 2018, 04:08:52 pm »
Why not use W7?  :palm:
Offline Jr460
« Reply #22 on: October 28, 2018, 04:09:11 pm »
Not only more ins and outs, but low latency, or very controlled latency.   Having an ASIO computable driver is a must if you want to do recording.  Making sure your PC doesn't have some other poor driver that doesn't play well and holds interrupts for too long, is also important.
Offline NiHaoMike
    • Facebook Page
« Reply #23 on: October 28, 2018, 04:15:38 pm »
Recording is a use case where it seems like USB boxes are the preferred solution nowadays. MsMadLemon says that no matter how many inputs there are on the box, there never seems to be enough. Maybe what we really need is a low cost, high SNR, and large number of inputs digitizer box? Probably would be good to base it around a Pocketbeagle (take advantage of the I/O accelerator hardware in the chip) or a low cost FPGA plus a FX2 for the USB interface. The FPGA solution would be better in terms of having very low latency and implementing antialiasing filters, but there are fewer open source developers able to work on it. Analog inputs would be handled by ADC modules, something like 4 or 8 stereo channels per module to allow expansion up to the limit of the system.
Or maybe use Ethernet since it's inherently isolated to prevent ground loops?
Offline Marco
« Reply #24 on: October 28, 2018, 04:26:38 pm »
C'T magazine used to test frequency response and year after year you just saw everything converging on flat. By this point even with the cheapest DACs and opamps there is just no excuse to not have good output, you have to intentionally screw it up ... it doesn't even save any money any more.
PS. Realtek's drivers suck though, every time there's a major windows update it reverts to their drivers on my laptop (rather than Microsoft generic) and there's some reverb with no controls to get rid of it.
« Last Edit: October 28, 2018, 04:30:53 pm by Marco »
