i like using which ever unit gives an easy number, so a sheet of paper is about 12 inches long, that's easier than 300mm. My soldering iron bit is 1mm wide, that's easier than a fraction of an inch, however the traces on the board are 6 thou wide.
As for temperature, when it's cold its celcius, so about 0 degrees C, however when it's hot I'd far rather it was 80 degrees F.
In the UK, we have both older imperial plumbing and more modern metric stuff and adaptors to connect the two are readily available. I believe that the French stuck with imperial rather than suffering the change.
