Author Topic: why to run transistors hot?  (Read 1807 times)
Offline strawberryTopic starter
  • Country: lv
« on: November 25, 2021, 10:29:45 pm »
what is benefit
Offline fourfathom
Re: why to run transistors hot?
« Reply #1 on: November 25, 2021, 10:36:19 pm »
Not needing to use a larger transistor?  As long as you have a comfortable margin there's no reason not to run a transistor a bit hot.  True, elevated temperatures accelerate device degradation, but normal "hot" operation isn't hot enough to make a big difference.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Offline John B
« Reply #2 on: November 25, 2021, 10:39:05 pm »
Uh, could we quantify these with some numbers?
Offline fourfathom
« Reply #3 on: November 25, 2021, 10:53:43 pm »
Ask a squishy question, get a squishy answer.
Offline mc172
« Reply #4 on: November 25, 2021, 11:06:38 pm »
what is benefit
They don't ever ask you to turn the heating on?
Offline Gregg
« Reply #5 on: November 26, 2021, 12:10:13 am »
Delta T: the hotter they are, the more heat they dissipate.  :=\
Offline Brumby
« Reply #6 on: November 26, 2021, 12:38:05 am »
With the information given, this is one of the better answers one could ever expect:
After all, they just need to survive long enough to pass any warranty period - and any statutory "fit for purpose" requirements.
Anybody offering high reliability products will try and reduce the operating temperature as much as possible.
Offline fourfathom
« Reply #7 on: November 26, 2021, 01:50:00 am »
As much as practical.  You're not going to add a cryo-cooler unless necessary.  When I think "hot", it's more like warm to the touch, but not uncomfortably so.  Once it gets painful then you need to know what you're doing, and knowing theta junction/case (and other specs) is critical.
  • Country: lv
« Reply #8 on: November 26, 2021, 05:03:51 pm »
modern electronics yes, after two y buy new one
but HP, Tektronix ..  metal can transistors can withstand higher heat but still why
Offline Miyuki
  • Country: cz
    • Me on youtube
« Reply #9 on: November 26, 2021, 05:12:12 pm »
You rarely want to go near the plastic mould temperature limit of 150-175°C, metal or ceramic parts can go higher, but not much when it is just a plain silicone
