Author Topic: Why won't it go wrong again?  (Read 8140 times)
Offline KJDS
    • my website holding page
« on: November 25, 2015, 04:22:45 pm »
I hate intermittent faults
especially ones that appear to have cured themselves, but I just know that if I sell the unit then it will come back the moment the customer turns it on
Offline AndyC_772
Re: Why won't it go wrong again?
« Reply #1 on: November 25, 2015, 04:48:22 pm »
I hate intermittent faults too
I hate ntermittent faults too
I hate intermttent faults too
Offline nfmax
« Reply #2 on: November 25, 2015, 04:50:14 pm »
Ah yes. You need to ensure the Critical Job Detector Circuit is active for the fault to occur. Been there, done that
« Reply #3 on: November 25, 2015, 04:57:27 pm »
ii
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #4 on: November 25, 2015, 05:26:23 pm »
It will go wrong again.  It just won't do so when you have it apart or are otherwise in a position to fix or troubleshoot it.  The random fault generator has built in sensors that disable it if tools are too close or the enclosure is open and the device under observation by a knowledgeable individual.
 |O
-Pat
Offline AF6LJ
« Reply #5 on: November 25, 2015, 05:30:18 pm »
You have to know how to work the intermittent.
Sitting there, watching it won't make it fail.
Sue AF6LJ
Test Equipment Addict, And Proud Of It.
Online xrunner
  • hp>Agilent>Keysight>?
« Reply #6 on: November 25, 2015, 05:36:05 pm »
Ke p at t un il you su ceed! D n't give p!
I am a Test Equipment Addict (TEA) - by virtue of this forum signature, I have now faced my addiction
Offline AndyC_772
« Reply #7 on: November 25, 2015, 06:23:06 pm »
Whenever I'm confronted with a problem like this, th6 absolU9& guar*eed wa to fix it i/ to a8&b fqpnUOIUFE 7s8
")b ` ` , wh^ch makes the fault occur every single time, then it's easy to debug it using standard lab equipment.
Offline gibbled
  • VE7mumble
« Reply #8 on: November 25, 2015, 06:55:59 pm »
Bob Pease book "Troubleshooting Analog Circuits" has a page on Troubleshooting Intermittent Problems.
One section reads:
"Try  to  make something happen. Applying heat  or  cold may give you a clue. Adding
some vibration  or  mechanical shock could cause a marginal connection to open permanently,
thus leading to identification of the problem and its solution."
Great book...
Offline Neilm
« Reply #9 on: November 25, 2015, 07:08:12 pm »
Just get a senior manager / customer to test - almost guaranteed it will go wrong.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline AF6LJ
« Reply #10 on: November 25, 2015, 08:08:33 pm »
One section reads:
Great book...
This is good basic advise; sometimes you have to look for that noisy voltage source or flaky logic levels, but you need to be on the ball when it fails in order to do some ten second troubleshooting.
As for intruducing heat;
Two of the best methods are the 100W incandescent bulb and fixture above the device under test or the towel placed over said device.
Every repair tech should have a goose neck desk lamp and one of those forbidden bulbs to insert in it. for this task. This is gentile on the device in question where a heat gun can do more harm than good in some cases.
Above all if you cannot get the problem to reappear by mechanical shock then check those voltage sources for noise and marginal ripple.
Sue AF6LJ
Offline DimitriP
« Reply #11 on: November 25, 2015, 08:19:25 pm »
Faults are permanent. Symptoms are intermittent. :)
They are more fun when you are in R&D mode than production.
Online Tomorokoshi
« Reply #12 on: November 25, 2015, 08:51:42 pm »
Will you be going to an EMC lab for evaluation? Even if you aren't, you could run it there and get test data. Budget permitting.
Sweep with a Variac?
Switch various loads on and off on the same circuit?
Flex the board?
As said above, heat and cold. Humidity?
Offline grumpydoc
« Reply #13 on: November 25, 2015, 09:25:28 pm »
Just sell it then the fault is sure to come back  >:D
You might have to travel to the buyer's location to fix, of course.
Is it anything especially sexy?
Offline AF6LJ
« Reply #14 on: November 25, 2015, 09:39:39 pm »
I have a reputation for fixing intermittents; fly me over and back and I will fix it.
Sue AF6LJ
Offline KJDS
« Reply #15 on: November 25, 2015, 10:00:34 pm »
It's one of a pile of radio test sets.
I've monitored the supply rails and they aren't moving when the fault is there.
I think now it's fully warmed up the fault has gone, so I'll leave it in a cold part of the house and see what happens in the morning.
Offline fivefish
« Reply #16 on: November 25, 2015, 10:54:45 pm »
Use the Shaolin Fists of Hammer method.
Offline DimitriP
« Reply #17 on: November 25, 2015, 11:47:22 pm »
Ok, since no one has asked specifically, what make model and symptoms do you have?
Online vk6zgo
« Reply #18 on: November 26, 2015, 12:29:34 am »
Take it up in a helicopter---works every time!
I had a small monitor which would fail as soon as it went into service in the "News chopper".
On the ground,you could heat it,freeze it,bash it,& it wouldn't fail!
I finally fixed it by the "scattergun" joint rework technique. ;D
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #19 on: November 26, 2015, 12:47:38 am »
And I thought this type of fault was normal, at least most of the stuff I work on are like this.
Offline MarkF
« Reply #20 on: November 26, 2015, 01:17:10 am »
I don't understand the problem.
    It's job security!     ;D
Online EEVblog
« Reply #21 on: November 26, 2015, 02:00:39 am »
Murphy.
Offline TerraHertz
    • It's not really a Blog
« Reply #22 on: November 26, 2015, 02:01:15 am »
You just need to understand the psychology of the intermittent fault gremlin. They are wily, hostile and ingenious, but may respond to threats. I find walking into the room with a grim expression and a large sledgehammer in my hand sometimes works.
Darnit. My 'm' key is going interittent.
Offline tonyarkles
« Reply #23 on: November 26, 2015, 03:57:28 am »
I do more software debugging than hardware debugging, but I've found this technique seems to be pretty useful: make a list of inputs, and turn them up to 11.
Software-wise, if you have a race condition that occasionally manifests when you've got two threads running... Run 20! A web server that starts having hiccups at 20 requests/second? Hit it with 200 req/sec! A database that occasionally runs out of RAM? Run something alongside it that takes a pile of RAM.
In hardware, it's the same deal. If your inputs are CMOS levels, run them as close to the switching thresholds as possible. Sag your voltage rails. Crank your voltage rails. Add noise to your rails and inputs. Runs your clocks fast. Hot. Cold.
And write down your hypothesis, along with what experiments you're doing to prove/disprove the hypothesis! Hopefully, you'll figure out what conditions take it from intermittent to consistent.
Offline Ian.M
« Reply #24 on: November 26, 2015, 04:46:59 am »
We used to take stubborn intermittants out on a road trip.  Stick it in the van for the round trip while doing a repair pick-up or drop-off for another customer, then carefully ease it back onto the bench and hope the fault has reappeared.
