Hi guys,
I'm having a bit of trouble with some questions on weird EM situations. Specifically:
1. Assume a cylinder* of a dielectric material, where wave propagation speed of light is lower than c. Lets say that it gets hit by an RF pulse (wave paket). Part of the pulse gets reflected, the rest travels through the material. Now let's rotate the cylinder very fast by 180 deg around its axis (which is perpendicular to where the pulse hit the object). The question: Will the RF pulse exit in the direction from which it came (basically will it travel with the mass of the object) or will it merrily travel onward, ignoring the movement of the object?
2. Assume a cylinder with a dipole antenna inside of it. This cylinder rotates at an extreme velocity. In a CW RF field, is there any rate of rotation during which the antenna will have a constant DC voltage on it?**
Thanks,
* - arbitrarily chosen shape, can be any 3D shape.
** - the antenna must be encased in something with a lower propagation speed than c, because to get a DC voltage the ends of the antenna would have to travel at c.
