If you can stand the voltage drop, the series diode does the trick,or even better,a bridge rectifier.
Of course,if the device is used in a car(CB,Ham radio,etc),& has one side of the chassis connected to (supposedly) earth/negative,& you wire it backwards,you can still short out the car battery via the mounting screws.
VK6ZG0
