Author Topic: will this sd card work with this camera  (Read 1596 times)
Offline sony mavica
« on: January 26, 2016, 07:28:41 am »
i want to buy a Samsung 64GB EVO Micro SDXC UHS-I will it work with this camera Kodak Zi8 i know ill need a sd card adapter
MORE POWER!
Offline Psi
Re: will this sd card work with this camera
« Reply #1 on: January 26, 2016, 07:34:37 am »
Probably not, looks like the camera only supports up to SDHC not SDXC.
Offline Philfreeze
« Reply #2 on: January 26, 2016, 08:55:40 am »
Exactly, you can use a SDHC card with a SDXC device but not the other way around.
A more complete guide: https://www.sdcard.org/consumers/sdxc_capabilities/
Offline sony mavica
« Reply #3 on: January 26, 2016, 09:07:14 am »
ty
MORE POWER!
Offline Stray Electron
« Reply #4 on: February 09, 2016, 12:30:19 am »
   Did you search on line?  I don't know anything about The Kodak camera but I used an OLD mini-SD card in an adapter in my new EM-1 and it worked fine until I could get more update hi-speed SD card. HOWEVER every camera/ memory card speed test that I've seen shows that those mini and micro SD cards were significantly slower than the current fast SD cards so I went with a new card since the EM-1 will shoot pictures at 10 shots per second and also HD video.  They weren't expensive, I bought two very fast 16 Gb Samsung cards from E-bay for $16 including postage.  At that price it's not worth the time and trouble to use an old card of any type.
   BTW I still have an old Sony Mavica that uses 3 1/2" disks. It still works and the battery still holds enough charge for a 2 hour shoots.
