Author Topic: Windows 10 can now show telemetry data  (Read 2274 times)
Offline HoracioDosTopic starter
  • Country: ar
  • Just an IT monkey with a DSO
« Last Edit: January 26, 2018, 01:26:33 am by HoracioDos »
Online Zero999
  • 0999
Re: Windows 10 can now show telemetry data
« Reply #1 on: January 25, 2018, 10:50:18 am »
I should bloodywell think so. This should have been the case, when Windows first started phoning home.
Offline Cyberdragon
« Reply #2 on: January 25, 2018, 09:43:19 pm »
PFFFT! I've terminated that crap on my PC a long time ago. ;D
https://www.safer-networking.org/spybot-anti-beacon/
I've also permanently disabled Cortana in the registry. ;D
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline rdl
« Reply #3 on: January 25, 2018, 10:06:15 pm »
Seeing that they are little more than lying, scheming thieves I would not make the mistake of believing that Microsoft will tell the whole truth.
Offline james_s
« Reply #4 on: January 25, 2018, 10:08:33 pm »
Or that they will not arbitrarily change something at any point down the road. The whole issue with the forced updates rolling release model is that the user gives up all that control and is expected to simply used what is placed in front of them. Microsoft forgot the personal part of "personal computer. "
Offline metrologist
« Reply #5 on: January 25, 2018, 11:27:25 pm »
can their IP range or site be blocked at the router?
Offline james_s
« Reply #6 on: January 25, 2018, 11:49:01 pm »
Yes, or you can disable the update service on your PC but then you never get any updates at all including security updates so that's not exactly optimal either. I lean toward that being preferable to handing over all control to MS though.
Offline Cyberdragon
« Reply #7 on: January 26, 2018, 03:11:53 am »
Like I said, get a program to remove the tracking for you. Just make sure you run it through a virus scan first (I've heard some are viruses).
*BZZZZZZAAAAAP*
Offline james_s
« Reply #8 on: January 26, 2018, 07:30:59 am »
Well my own solution is to continue using Windows 7 at home and Ubuntu at work.
Offline David Hess
  • DavidH
« Reply #9 on: January 26, 2018, 03:18:04 pm »
So I cannot get updates which will break things and remove features?  I fail to see a problem here.
