Author Topic: What category does 555 count?  (Read 3577 times)
Offline technixTopic starter
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« on: November 13, 2015, 11:34:03 am »
I have 4 boxes for THT components:
  • Resistors, Capacitors, Inductors and Connectors
  • Diodes, Transistors, Thrysitors and Heatsinks
  • Analog and Mixed-signal Integrated Circuits (excl. anything that have a CPU inside) and Relays
  • Digital Integrated Circuits, mixed-signal MCU, MPU and SoC.
I place ICL7135, ADC0832 and MCP41010 in Analog & Mixed Signal box, but ATmega328P and ATtiny85 in Digital box. Now where should 555 go? (Currently they are in the "analog & mixed-signal IC" box)
Offline halexa
Re: What category does 555 count?
« Reply #1 on: November 13, 2015, 12:30:58 pm »
It doen't matter which box you put it in.
As long as you can find it the next time you need a 555 timer.
Offline fivefish
« Reply #2 on: November 13, 2015, 12:39:00 pm »
There's a big category called "Linear ICs"
I quote from google
"A linear integrated circuit (linear IC) is a solid-state analog device characterized by a theoretically infinite number of possible operating states. It operates over a continuous range of input levels. In contrast, a digital IC has a finite number of discrete input and output states."
Offline 6581
« Reply #3 on: November 13, 2015, 12:40:23 pm »
555 is in its own category "triplefives" and deserves its own handmade wooden cabinet with silk lining.
Or you can put them with any other chips. :-) Sounds like your current choice is fine.
Offline zapta
« Reply #4 on: November 13, 2015, 02:10:03 pm »
Perfect answer.
Offline ConKbot
« Reply #5 on: November 14, 2015, 04:03:04 pm »
Digikey says "clock and timing" and I'd be inclined to agree.
Though I'd consider non clock/timing/pulse stretcher projects more interesting, due to their creative use of the 555. I.e.
http://www.electrobob.com/555-class-d-amplifier/
Offline hans
« Reply #6 on: November 15, 2015, 10:05:58 am »
If you want to keep your current categorization, I would also put it into analog chips.
After all, the 555 functions as a timer by the use of analog circuits (R-C circuit), over maybe a digital timer that uses an oscillator/clock and digital counter.
Offline JoeN
  • We Buy Trannies By The Truckload
« Reply #7 on: November 15, 2015, 08:39:28 pm »
Have You Been Triggered Today?
  • Country: cn
    • My Untitled Blog
« Reply #8 on: November 16, 2015, 12:55:49 am »
You should have more than 4 boxes.  64 is the starting point.  I have 6 of these.
http://www.globalindustrial.com/p/storage/cabinets/drawer/plastic-drawer-parts-cabinet-10164-20w-x-6-3-8d-x-15-13-16h-black-64-drawers
I have LOTS of Zip-locks inside those 4 boxes.
Offline JoeN
« Reply #9 on: November 16, 2015, 02:25:47 am »
In addition to the 64 slot shelving units, I also have Sterelite latching modular stackable boxes (http://www.walmart.com/ip/44785779) where the stuff inside them is sometimes organized by zip-lock baggies.  Problem is, parts organized that way are hard to find.  It's a frigging sequential search every time.  Putting no more than 2-8 parts in each of the small drawers makes stuff a lot easier to find.  Mostly I use the Sterilite boxes for larger parts.
Offline JoeN
« Reply #10 on: November 16, 2015, 02:33:23 am »
This is how I use the stackable boxes using 4 of the available sizes that stack up really nicely.
