Hi folks,
I have a small office running WinXP machines (5 computers) all tied in to a single Windows server. I have started to migrate (at least some of the client machines) to virtual machines running Win XP Mode in VirtualBox.
I managed to successfully get 1 machine running no problem by creating a WinXP Mode machine and giving it the old WinXP PRODUCT KEY of that specific computer. It detects the Windows Server, gets proper user authentication to log in to the domain, I have access to the shared drives, all good. When I full screen it feels like running natively.
I decided (to be quick) to just CLONE that virtual machine to my other client computer. At first it booted up and accessed the network no problem. That worked for a few months! Everything worked great, the machine was an exact clone, same computer name, username/password was used, both machines ran at the same time and access the Windows network and shared server no problem.
Recently, it stopped working on the second cloned machine. I am trying to log in to my network and it keeps giving me an error about unable to login to the domain, can't find the server, etc. If I disconnect the network (it is Bridged) I can log in locally using the last known password (from a month ago when it worked), but it has no connection to the server. As soon as I turn on the network access again, Windows gives me an error that my credentials are wrong and I need to login again (Ctrl-Alt-Del to LOCK computer and login again) because the password changes monthly. But when I try the NEW password it gives me that error.
I've pulled out my hair trying to figure out what is wrong. I know it's not the network setup and it sounds to me like the 2nd machine is detecting the Windows server because it is telling me my credentials are wrong. I can also change the computer ID/network name by logging in as the administrator of the network, so the client machine must be talking to the User Authentication on the server.
So the only thing that I can come up with is that for whatever reason, after several months of using Win XP Mode on the 2nd cloned machine with no problems, NOW it may have detected that both machines have the same PRODUCT KEY and the server is having an issue allowing 2 different WinXP Mode machines with the same key connect?
By the way, BOTH client computers still has the original WinXP on it (I set up the new boot and virtual machine as a separate partition and boot). So when I boot up the old WinXP directly on the 2nd machine (that has the cloned VM of WinXP Mode) it works fine. I also have the product key for this 2nd computer. So I could make a NEW WinXPMode VM and enter in the 2nd computer's PRODUCT KEY but I didn't want to go through the trouble of doing all that. Also, WinXPMode does not allow changing the product key after installation like WinXP does (I can't just change the registry value and run the OOBE program to initiate a new activation).
SO... Has anyone heard of this? Is this because of using the same PRODUCT KEY on more than one client machine logging in to the same Windows Server network? Why did it work initially for a few months and only now give me problems? Should I just scrap the 2nd clone and make a NEW clone and see if that works (maybe the original got corrupted or just worked as long as the password authentication hadn't expired)? Otherwise I will have to just go ahead and create a new VM with the PRODUCT KEY of the 2nd client machine, I just didn't want to waste the time if it was something else simple to try first.
