Author Topic: Just to show that you can sell anything on eBay  (Read 6730 times)
Offline rdl
« on: March 01, 2015, 04:28:55 pm »
You've got to be kidding me. Over a thousand people have bought this power supply with Pink binding posts?
http://www.ebay.com/itm/30V-5A-110V-Precision-Variable-DC-Power-Supply-Digital-Adjustable-Lab-w-clip-New-/171607017649
Offline babysitter
  • pushing silicon at work
Re: Just to show that you can sell anything on eBay
« Reply #1 on: March 01, 2015, 04:30:22 pm »
Ripple Noise: ?1 MVRMS(RMS)
1 Megavolt RMS? They should add some filtering, really |O
Recovery Time: ?100?S
Time measured in Microsiemens. Fine. Might reduce the resistance against waiting for recovery.
I'm not a feature, I'm a bug! ARC DG3HDA
Offline cosmicray
« Reply #2 on: March 01, 2015, 04:33:06 pm »
I bet they got them for super-cheap. Something the manufacturer made in error.  :palm:
it's only funny until someone gets hurt, then it's hilarious - R. Rabbit
Online PA0PBZ
« Reply #3 on: March 01, 2015, 04:45:26 pm »
Looks like all the red was used for the power button...
Offline Tandy
  • Darren Grant from Tandy, UK.
    • Tandy
« Reply #4 on: March 01, 2015, 04:48:44 pm »
Looks like the label on the top has been made with a Dymo tape printer.
For more info on Tandy try these links Tandy History EEVBlog Thread & Official Tandy Website
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #5 on: March 01, 2015, 04:51:04 pm »
That photo looks shopped - the main display looks wrong
Day Job: Mostly LEDs
Offline Richard Crowley
  • KE7GKP
« Reply #6 on: March 01, 2015, 05:05:11 pm »
Looks like it was designed by someone who is color-blind.
Yeah, the numeric display in the first photo is fake,
but then most photos of 7-segment displays are faked in marketing photos.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #7 on: March 01, 2015, 05:11:04 pm »
I'm impressed that they actually labeled the thing, and took a photo of it (or did a reasonable photoshop).  Others I've seen, the brand is literally pasted in with Paint.
I'm curious who actually makes the things.  Does everyone make them?  Does the OEM not sell their own brand, so they let everyone and their dog do the marketing and branding?
In any case, there's not a single thing with those shitty metal boxes and oval buttons that I'm ever wasting my money on!
Seven Transistor Labs, LLC
Offline CatalinaWOW
« Reply #8 on: March 01, 2015, 05:39:31 pm »
For two dollars more you can get one with a red terminal and grey power switch.
http://www.ebay.com/itm/Precision-Variable-Adjustable-30V-5A-DC-Power-Supply-Digital-Regulated-Lab-Grade/280901249540?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D29381%26meid%3D961be192c1c64462a9c42c12274c846e%26pid%3D100005%26rk%3D2%26rkt%3D6%26mehot%3Dpp%26sd%3D171607017649&rt=nc
Actually who knows what color these things are.  Why would you expect the quality of the photography to exceed the standards elsewhere in the product?
Offline rdl
« Reply #9 on: March 01, 2015, 05:59:34 pm »
When did yellow replace green as the standard color for chassis/earth ground? Why is the ground terminal between positive and negative? Why is the power button 4 times larger than it needs to be? Why is the handle on top instead of the side? Why do they put so little thought into product design?
Offline electr_peter
  • Country: lt
« Reply #10 on: March 01, 2015, 07:34:03 pm »
It is one of the cheapest adjustable medium power supply, so people will buy it no matter what. Outer size and buttons are very standard, I do not see power switch as too big - it always (>10 years) was like this on this type of PSU.
Also, it is well known fact that the same plastic moulds can be used with any plastic of the same type (but different colour). Some factory simply ran out of the right colour plastic and used leftovers. Non standard colours may be 0.01% cheaper too.
Offline Flump
« Reply #11 on: March 01, 2015, 07:44:59 pm »
personally i don't care what color the binding post is as long as i don't get it mixed up with the others
Offline zapta
« Reply #12 on: March 01, 2015, 07:46:13 pm »
Drain the swamp.
Offline T3sl4co1l
« Reply #13 on: March 01, 2015, 09:42:38 pm »
That, or it was a replacement.  Seems unlike HP to allow that out of the factory.  That said, it's probably tricky to ensure such things in manufacturing... the bench jockey reaches in one bin, pulls out a connector and bolts it in... reaches in another bin, and so on...  Likewise during inspection, even if it's an itemized checklist noting all of these... people make mistakes.
Automated insertion or inspection would avoid that, most likely (the worst case being, a whole run of them end up wrong because some jerk dumped the wrong bin in the machine -- same root problem of course!).  But such connectors I don't think have that kind of option.  There are board mounted kinds, but... yeah. :P
Offline rdl
« Reply #14 on: March 01, 2015, 10:24:06 pm »
Nope, that was the way HP used to make them. I have an E3610A that has the red-red-black. I always thought it was one of the dumber things they did. Just goes to prove that no one is immune to poor design. Shortly before they turned into Agilent, they did switch to the red-black-green colors. I've seen HP models both ways, but I don't think I've ever seen an Agilent without the green ground post.
« Last Edit: March 01, 2015, 10:44:15 pm by rdl »
Offline codeboy2k
« Reply #15 on: March 01, 2015, 11:09:02 pm »
I like (+)  (-)  (GND) ,  not  GND in the middle.
A lot of chinese supplies seem to have PE GND in the middle like that.  It means you can't use a dual banana jack to BNC, which I like sometimes, and with a BNC to grabbers at the other end.  They often show pictures that have PE GND strapped to the (-) of the PSU, so I think that's why they do it that way.   HP has a few older PSUs with PE GND in the middle too, so they are guilty as well.  There is no standard, although many people have a preference, one way or another.
I much prefer the older triangle arrangement, with PE GND above and centered between the (+) (-) , or at least at a right angle, with (+) (-) side by side at 3/4" spacing, and the PE GND above or below the (-) jack, again at 3/4" spacing.
Agilent's current models seem to have it in a good arrangement and with proper spacing.
Offline babysitter
« Reply #16 on: March 02, 2015, 04:34:18 am »
HP also makes power supplies with funny post colors. For example, this one has a red (-) post.
http://www.ebay.com/itm/Agilent-HP-E3617A-DC-Bench-Power-Supply-Single-Output-ID-24304-TEST-/161265640596?pt=LH_DefaultDomain_0&hash=item258c2e6494
Fixed my double-red HP36XX with some green and yellow nail polish.
Offline zapta
« Reply #17 on: March 02, 2015, 06:20:04 am »
There are quiet a lot HP units with red red posts. They made them with two different color combinations.
Drain the swamp.
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #18 on: March 02, 2015, 06:46:16 am »
Marketing Bloke: "You know, everybody and their donkey is selling these things. We need something to set us apart".
Boss: "Okay, you're getting a pink post".
Marketing Bloke: "What?? No, wait, that's..."
Boss: "Pink. Post. Now get out of my office".
Offline Moshly
  • What's wrong with this thing
« Reply #19 on: March 02, 2015, 07:10:27 am »
How about, lets get a ghetto blaster & put bulbs in the speakers and then get Nyan-cat to vomit a rainbow all over it ->
http://www.ebay.com.au/itm/Vela-Disco-Lite-Boombox-Ghettoblaster-Vintage-Breakdancer-Stereo-100-Working-/321673618848?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2047675.l2557&nma=true&si=0F91jmLZBCZqaDEd3MyGTnW5Nws%253D&orig_cvip=true&rt=nc
I just cant work out if it was purchased by an audiofool or a visualfool, but definitely a got too much money fool  :palm:
