Author Topic: Wipe Off the Battery Before Use?  (Read 1084 times)
Offline Boris_yoTopic starter
  • Country: il
« on: October 18, 2022, 04:59:47 pm »
Hi. What is the purpose for wiping off the lithium cell battery before using it?
I found it mentioned on a few websites.
Offline ataradov
    • Personal site
Re: Wipe Off the Battery Before Use?
« Reply #1 on: October 18, 2022, 05:26:01 pm »
I would assume they don't want the finger grease and sweat to cause oxidation and poor contact over time.
Alex
The following users thanked this post: Boris_yo
Offline pcprogrammer
« Reply #2 on: October 18, 2022, 06:56:46 pm »
And to not create a restive bridge between the two poles, which shortens the battery life. Best to touch these batteries as little as possible.
I usually try to leave it in the plastic and slip it into place without touching it at all.
Offline james_s
« Reply #3 on: October 18, 2022, 08:42:50 pm »
It's the latter. Finger oils contain salts and these combined with moisture forms a slightly conductive film. It's not much, but when spread over the multiple years these small cells can last it doesn't take much leakage current to significantly reduce the lifespan.
  • Country: il
« Reply #4 on: October 19, 2022, 12:44:50 am »
This is only relevant to CR2032 and similar sized lithium cell type batteries? What about small sized batteries like LR44 and AG3? And lithium/alkaline AAs/AAAs? 9v rectangular battery?
Offline ataradov
    • Personal site
« Reply #5 on: October 19, 2022, 12:50:21 am »
It is relevant for all types of batteries, but it has most impact on small batteries that don't have a lot of capacity to begin with. Discharging even AAA battery though dirt and grime traces would take a while and self discharge would likely to be higher anyway.
Alex
Offline Halcyon
  • Global Moderator
« Reply #6 on: October 19, 2022, 03:25:05 am »
I was always taught to give contacts and button cells a clean with alcohol when replacing them. So I've always done it that way. I mean, if for no other reason that it's nice and clean.
