As already noted, wireless charging is full of drawbacks. It's only good for the uber lazy who can't be arsed to spend half a second to connect a damn cable. Nothing more than a gimmick.
I just got a set of parts to play with (mail just arrived)
at first test, it looks good, actually. but time will tell.
I bought these to try out:
https://www.amazon.com/gp/product/B00MN3RR7Qhttps://www.amazon.com/gp/product/B00HJ2KEMQa very low-priced base (which has mixed reviews) and a very low priced receiver coil 'card'.
the card is nice. it fits perfectly in my ancient android phone and also fits perfectly in my portable audio player. it does eat up a micro usb port and on my audio player, that is a problem since the usb port can be used for charging as well as OTG usb mem sticks for extra storage. might see if I can tap into the power leads directly and save the usb port for data.
the pad is big which I like since you don't have to balance the charged device on a tiny little puck.
also tried the adafruit coil unit and that seems to give me exactly 5.00 volts (on my fluke) when I sit it on the charging pad. here's the adafruit diy card in my hand, for size comparison:
soldering 2 wires to the bottom 2 pads does give me that 5v as it should.
as for being lazy, its not always about that. samsung, for example, has a known history of their usb ports being somehow different from many cables. lots of direct experience with this (I used to work at an android tech company and lots of peoples' samsung phones would not charge with micro usb cables that worked for other phones). the micro usb port is better than mini usb but it still can fail and it does on lots of devices.
wires are annoying. I converted to a cordless mouse over a decade ago and never went back to a wired mouse. wired keyboard, ok, but mouse moves around and is natural for wireless.
same with small devices. I want to be able to pickup and use the phone for a bit but then put it back down and have it resume charging. why deal with cords when you can pick it up, use it, put it down and there's no tangle? seems like a total win to me, as long as you are not in a hurry to get the device charged. if its always left on the pad, its always catching up and at least not draining the battery, as is the usual case when its not connected to a charger of some kind.
I'm going to give this tech a few months testing to see how it works out and what issues I'll find over time. but so far, I really like the idea, at least.
