Ok, some links to illustrate situation:
About soaring autism:
Here same stats are linked to glyphosate:
http://images.medicaldaily.com/sites/medicaldaily.com/files/styles/embedded_full/public/2015/01/05/autism-prevalenceuse-glyphosate.JPGHere to organic food sales
https://www.sciencebasedmedicine.org/wp-content/uploads/2014/09/autism-organic2.jpgOnly thing can conclude that autism IS soaring, but is anyones guess why. In such situation makes sense to rely on personal experience and observations.
Now back to ELF:
Here some dude says link to powerlines exists:
http://www.bmj.com/content/330/7503/1290Later same dude says basically no link (after manipulating stats in a bit different way):
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC2965853/So again
Here some other studies:
Ahlbom, Anders; Elisabeth Cardis, Adele Green, Martha Linet, David Savitz, Anthony Swerdlow (December 2001). "Review of the Epidemiologic Literature on EMF and Health". Environ Health Perspect. 109 (S6) - [View abstract]
Fews, Peter; Denis Henshaw, Paul Keitch, Julie Close, Richard Wilding (December 1999). "Increased exposure to pollutant aerosols under high voltage power lines". Int J Radiat Biol. 75 (12): 1505-21. - [View Abstract]
Fews, Peter; Denis Henshaw, Richard Wilding, Paul Keitch (December 1999). "Corona ions from powerlines and increased exposure to pollutant aerosols". Int J Radiat Biol. 75 (12): 1523-31. - [View Abstract]
"SAGE first interim assessment: Power Lines and Property, Wiring in Homes, and Electrical Equipment in Homes" - [Summary plus downloads]
Here we finally see some indication of brain activity, for example
Aha! Second order effects! Someone took head out of his ... for a moment...
Lets try to go down this path:
http://www.sciencealert.com/study-finds-that-chronic-stress-really-does-spread-cancer-in-the-bodyStress... Hmm... Maybe ELF contributes to stress? And stress messes up health?
After all man is eletrical machine, if it transmits, maybe shall receive also, and Rx modulates some internal processes?
http://www.measurement.sk/2005/S2/Lipkova.pdfBut back to stress:
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4256039/"
Our data demonstrated that the responses observed in the animals after exposure to the different frequencies of ELFEMF (1 and 5 Hz) may differ according to the frequency, and time of exposure. These data also indicated that one of the most prominent organs which can be activate after field exposure is at least some parts of the brain, which manifested by changes in behavior and hormonal level in the animals. In other word, our data explained the hazardous of the field exposure which can destabilize all body organs by the mechanisms which are not fully understand."
And just to spice up:
https://www.hindawi.com/journals/bmri/2015/237183/"
In conclusion, we demonstrated that 50?Hz ELF-EMF exposure can induce the alterations of genome-wide methylation and the expression of DNMTs. These results suggest that epigenetic regulation might play an important role in the biological effects of 50?Hz ELF-EMF exposure. Although we could not confirm whether the long-term exposure of alternating current does harm to our health based on the present study, we recommend that charge power supply and high voltage wire should be kept as far as possible from our body to reduce the absorption of radiation by cells."
So it's all very much open do discussion, nothing is "debunked" and no "final word" is said.
