AFAIK, WiGig is primarily meant to be used as short range (in your apartment or office) high throughput WiFi. Microwave PtP links with Gbit/s throughput are nothing new, we had them already 20 years ago. Typically you would get a licence for a dedicated frequency (instead of a shared ISM band) and run your microwave link over several km. A common application is the backhaul connection for celluar base stations, especially in rural areas without glass fiber. BTW, the terminology for 'open-sight' is line-of-sight (LOS), and the opposite is non-line-of-sight (NLOS).
