Author Topic: Wireless network SSID naming  (Read 5988 times)
Offline Halcyon
  • Global Moderator
« on: January 28, 2017, 06:33:13 am »
I'm thinking about SSIDs for my home network. For years I've used just Home Network, Un-trusted Clients, Guest Network etc...
I was considering using my actual address such as 1 Something Place (Guest) as an example. Can anyone think of any negatives by doing this?
Yes, it'll identify to my neighbours who's taking up most of the channels on the 2.4GHz band but so what? It would be easy enough for someone to find that out (or guess) anyway. You won't see the network appear anyway unless you already know my physical address and are probably within viewing distance of it.
« Last Edit: February 01, 2017, 01:29:53 am by Halcyon »
Offline bitseeker
Re: Wireless network SSID naming
« Reply #1 on: January 28, 2017, 06:58:24 am »
Your home address would become readily available via services such as https://www.wigle.net/
I also wouldn't put "DMZ" or "Guest" in the SSID thereby informing outsiders what may or may not be available at each access point.
I TEA.
The following users thanked this post: Halcyon
Offline Halcyon
  • Global Moderator
« Reply #2 on: January 28, 2017, 07:07:50 am »
Very good point. That's enough to me not to even consider it.
I did think about that as well, but I need a fairly clear way of differentiating between them.
Offline MarkF
« Reply #3 on: January 28, 2017, 08:27:22 am »
I named my network after my favorite cartoon duo.  Easy to tell they go together but no other give away.
Offline Ampera
    • Ampera's Forums
« Reply #4 on: January 28, 2017, 09:52:01 am »
As a person who has WAY too many APs all at once in my house, I have a naming scheme.
My first AP, which was a 2.4ghz 802.11 N deal is named AMP-N
My second, which was a dual band 2.4 and 5ghz 802.11 N/AC deal is named AMP-2.4ghz and AMP-5Ghz
I suggest something simple. Take your username (Mine is Ampera on other sites) and shorten it to 3-5 characters. Now take the router frequency and 802.11 standard and add that.
Now number it among APs if you have multiple points with the same configuration.
Professional complainer-in-chief criticizing other people's code
Programmer and bumbling Unix fool
Op @ EEVBlog IRC: irc.austnet.irc #eevblog
Offline ovnr
  • Country: no
  • Lurker
« Reply #5 on: January 28, 2017, 10:31:57 am »
<3 my Ubiquiti APs. You get a single SSID for the whole lot (and both frequencies), and clients just Deal With It (tm), roaming between APs and frequencies as needed.
Offline kripton2035
« Reply #6 on: January 28, 2017, 10:36:02 am »
+1
Online steve30
    • Stephen Coates' Homepage
« Reply #7 on: January 28, 2017, 01:33:54 pm »
For 10 years I've had an AP named 'steve'. I don't really use wireless anymore so now its only turned on when I particularly want it.
'steve' sounds a little bit boring, but it is actually quite unique in my area. Most of the SSIDs which are broadcast round here have names like 'SkyXYZ' or 'TalkTalkXYZ'
Offline David Hess
  • DavidH
« Reply #8 on: January 28, 2017, 10:15:09 pm »
If I was concerned about security, then I would pick an SSID which is similar to the other SSIDs in my area just to confuse a potential wardriver.
Offline bitseeker
« Reply #9 on: January 28, 2017, 10:23:19 pm »
Fun! :-+
I TEA.
Offline imidis
« Reply #10 on: January 28, 2017, 10:23:41 pm »
CIA Van is one of my favorites in the neighborhood. :)
Gone for good
The following users thanked this post: BillyD
Offline timb
    • timb.us
« Reply #11 on: January 28, 2017, 10:51:30 pm »
Yup, the Apple Airport/Time Capsules do this as well. It's very nice! Though, personally I still use the option to assign separate SSIDs to the 2.4 and 5GHz bands. (Because sometimes I'm in an extreme corner of the house and want to be able to force the system onto 2.4GHz.)
Online Ian.M
« Reply #12 on: January 28, 2017, 10:52:10 pm »
Fun! :-+
Its no substitute for proper security, but there is a reasonably good case for picking a SSID for your network that looks like the typical default SSID for a wireless printer as no-one expects a generic wireless printer to have Internet connectivity. Pick one with no known exploits in the wild and of a brand you do not own!
Offline bitseeker
« Reply #13 on: January 28, 2017, 11:06:00 pm »
Hmm, I wonder if one could have an SSID made up of space characters. I suspect firmware would trim spaces, which would thwart this from occurring.
Aha, perhaps I'll use:     ...---...
I TEA.
Online Ian.M
« Reply #14 on: January 28, 2017, 11:08:30 pm »
A good one for casual deterrence of idiots is '--No SSID--'  >:D
Offline bitseeker
« Reply #15 on: January 28, 2017, 11:11:53 pm »
Fantastic! :-DD
Also: SSID Hidden
I TEA.
Offline Halcyon
  • Global Moderator
« Reply #16 on: January 28, 2017, 11:36:14 pm »
I use 3 Ubiquiti access points with a controller so there is no need to "name" each AP. It all appears as one SSID that services both 2.4 GHz and 5 GHz clients.
Refer to the screen shot below; All anyone sees is one SSID called "Home" but if you use a Wi-Fi analyser, you can see there are several access points servicing that network.
« Last Edit: January 28, 2017, 11:56:11 pm by Halcyon »
Offline Brumby
« Reply #17 on: January 28, 2017, 11:44:59 pm »
There are a couple of networks that come up on my WiFi scan.
The one that made me smile is this one:  No Wifi For You :)
Online BillyD
  • Country: ie
« Reply #18 on: January 28, 2017, 11:54:21 pm »
A good one I heard recently:
  tellMyWifiLoveHer
Offline David Hess
  • DavidH
« Reply #19 on: January 29, 2017, 12:01:31 am »
I like "FBI Porn Server".  The CIA is not chartered for domestic operations.
I agree but why give away anything for free?  It is better to hide in plain sight with a nondescript SSID than to disable SSID broadcasts or even use a MAC white list both of which just gives a false sense of security.
If I am paranoid enough, then the WiFi goes on its own separate subnet but is isolated from the LAN.  If I am really paranoid, then access between the WiFi and LAN is only via VPN.  If I am more paranoid yet, then I isolate all of my LAN machines from each other on layer 3; a VLAN switch connected to a real router is handy for this.
« Last Edit: January 29, 2017, 12:03:30 am by David Hess »
Offline David Hess
  • DavidH
« Reply #20 on: January 29, 2017, 12:15:57 am »
Usually as long as the access points are on the same subnet and ethernet broadcast domain, roaming between access points will work whether the SSIDs are the same or not.
Offline trophosphere
« Reply #21 on: January 29, 2017, 12:31:59 am »
There is one in my neighborhood that is named "NSA Surveillance Van".
Offline Halcyon
  • Global Moderator
« Reply #22 on: January 29, 2017, 12:37:32 am »
Yes it's a quick and dirty way of doing it but involves more configuration. Why configure 3 access points on each client (or 6 if I want to use both bands) when I can just do one? It's also the reason why I'm going to ditch pre-shared keys for 802.1x authentication, that way I can simply set up a guest login which I can change (or even disable) at will, without then having to go around to every other device on the network and change the settings. The less configuration needed at the client end, the better.
Offline bitseeker
« Reply #23 on: January 29, 2017, 12:38:49 am »
I use the same app. Very handy.
I TEA.
Offline David Hess
  • DavidH
« Reply #24 on: January 29, 2017, 12:50:27 am »
I agree that is more convenient.  I do not think it is a big deal if you just have enough access points to cover a home.
