Author Topic: With Travel Halted, What Happens To The Planes?  (Read 6865 times)
Online Alex EisenhutTopic starter
  • Place text here.
« on: August 09, 2020, 04:42:25 pm »
https://youtu.be/D9uZmmoexUk
I thought it was interesting.
Online Monkeh
The following users thanked this post: Alex Eisenhut, Gyro
Offline Gyro
Re: With Travel Halted, What Happens To The Planes?
« Reply #2 on: August 09, 2020, 05:40:32 pm »
Also, this happens: https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAD.nsf/0/ec0e5875b315e9e5862585ae007cd448/$FILE/2020-16-51_Emergency.pdf
From the Background section:
This condition, if not addressed, could result in compressor stalls and dual-engine power loss without the ability to restart, which could result in a forced off-airport landing.
  :palm:
Presumably it's another one that applies to all those 737Maxs that have been sitting on the ground around the world for over a year now - probably not the only valve!
« Last Edit: August 09, 2020, 05:43:10 pm by Gyro »
Best Regards, Chris
Online Monkeh
« Reply #3 on: August 09, 2020, 05:45:40 pm »
Possibly, it depends on the valve design and orientation. They're not the same engines. If they ever get the Max back off the ground they'll be in for a complete overhaul first, I imagine.
Offline Gyro
« Reply #4 on: August 09, 2020, 06:06:30 pm »
I wonder how many 'Engine bleed air 5th stage check valves' Boeing have in stock!
Best Regards, Chris
Online IanB
« Reply #5 on: August 09, 2020, 06:17:13 pm »
I get the feeling this means "a crash"  :-\
Offline jogri
« Reply #6 on: August 09, 2020, 06:42:06 pm »
No, this means a descent with descent rates that may or may not be fully approved for passenger flights by the airplane manufacturer, followed by a landing at a non-ICAO registered aerodrome. This procedure may be followed by an unscheduled rapid disassembly either during the descent phase or during the landing.
The following users thanked this post: tom66, Gyro
Offline Gyro
« Reply #7 on: August 09, 2020, 06:44:23 pm »
Spade -> 'Earth inverting horticultural instrument'.  :D
Best Regards, Chris
Offline ConKbot
« Reply #8 on: August 10, 2020, 04:15:43 am »
https://en.wikipedia.org/wiki/TACA_Flight_110
They are keeping it optimistic.
Offline paulca
« Reply #9 on: August 10, 2020, 09:24:45 am »
Plausibly, but you'd be amazed at how far a full airliner can glide.... if it has altitude to do so.
Offline WattsThat
« Reply #10 on: August 10, 2020, 03:31:03 pm »
No doubt you are referring to this example:
https://en.m.wikipedia.org/wiki/Gimli_Glider
Any aircraft that crashes in an uncontrolled fashion due to the loss of power is the very definition of pilot error. There is no excuse for losing control of an aircraft due to a loss of propulsion. Period. You do not stop flying the aircraft until it is no longer moving.
Aviate, navigate, communicate.
Online langwadt
« Reply #11 on: August 10, 2020, 03:42:49 pm »
  :palm:
If you had read it you would know that it only applies to the 737NG not the Max, it has different engines
« Reply #12 on: August 10, 2020, 07:06:57 pm »
Likely not many, the more important thing is how many can the manufacturer and the designated overhaul facilities overhaul per week, as those kinds of equipment are designed to be overhauled and repaired multiple times in their operational life.  The more worrying thing is that many of the parts will have time expired during this period, and will need to be taken out and replaced, plus the majority of these aircraft are being stored in far from ideal conditions, and with far from ideal preparation other than put covers on and tape up ports. you will find many will have unseen corrosion, and many will have failures almost immediately after being placed back into service.
Batteries as well are a worry, as they will have needed to be removed and stored in a battery maintainer that keeps them properly charged, but likely they are just left disconnected in the avionics bay at best, or have been left connected and thus have overdischarged to the point they are useless, or for the lithium ones, have dropped down to the point the controllers have deemed them unusable and failed them.
Going to be a lot of the older fleet going into scrap metal as well, at least those that are fully paid off, so that the scrap price, after salvaging all saleable parts for other aircraft, is more than the cost of scrapping them. You are also going to find a lot of lease aircraft in a quandry, not worth much any more, still under loans, and not able to earn income, plus every month the bill for storage increases. Going to be a lot of airlines closing and merging, and quite a few national carriers (the one here for instance) are going to either need massive government funding, or will be closed, restructured or sold off.
Friday was the first time I had seen any RJ's fly out of the airfields near me for some time, and there is a distinct lack of air traffic to the major airline as well, though there is still a fair amount of helicopter traffic, as most of it is for medical cases, and for military use.
Offline Rick Law
« Reply #13 on: August 10, 2020, 07:31:02 pm »
[RL: Bold added to quote]
Pardon my ignorance, what does "unscheduled rapid disassembly" means?  Is that some kind of airline lingo for the plane falling apart while descending for the landing?  If so, this euphemism totally obscure the reality here.
Offline peter-h
« Reply #14 on: August 10, 2020, 07:38:32 pm »
Ignore it; he's playing with you.
That valve jamming is potentially a loss of much or most of the engine power, which is bad news if it happens in both engines at the same time. Google BA038 for example.
Online langwadt
« Reply #15 on: August 10, 2020, 07:38:43 pm »
and airliner doesn't just fall out of the sky because it loses engine power
Online langwadt
« Reply #16 on: August 10, 2020, 07:42:25 pm »
if the valve gets stuck the compressor stalls and the engine automatically shuts down and cannot be restarted
Offline jogri
« Reply #17 on: August 10, 2020, 08:20:32 pm »
It's a term that is commonly used as an euphemism when a rocket decides to blow up. Afaik no airline uses this term (but SpaceX uses it to describe their landing failures), it's just a joke phrase like "the front fell off".
Online IanB
« Reply #18 on: August 10, 2020, 08:25:27 pm »
 :palm:
Offline sleemanj
  • Professional tightwad.
« Reply #19 on: August 10, 2020, 09:26:41 pm »
Gimli might be the more famous, but Air Transat is way more pucker inducing...
https://en.m.wikipedia.org/wiki/Air_Transat_Flight_236
120km glide over the open ocean to the Azores (and they still had to lose excess altitude!).  A good example of how airliners are more like massive self launching sailplanes than we give them credit for.
« Last Edit: August 10, 2020, 09:29:02 pm by sleemanj »
Offline WattsThat
« Reply #20 on: August 10, 2020, 10:29:01 pm »
That you for the Air Transat link, I was unaware of that event.
I am not surprised that both pilots mentioned had glider ratings. With that experience, one learns from your first flight that without power, you get one and only one chance for a successful landing.
Offline Rick Law
« Reply #21 on: August 11, 2020, 02:20:06 am »
Yeah, that's what I thought.  A way over the top euphemism.
Online IanB
« Reply #22 on: August 11, 2020, 02:24:31 am »
Reading the story of Air Transat was also disturbing. Two experienced pilots were flying a plane in which fuel was disappearing much faster than their flight plan said it should be consumed by the engines. So much so that alarms went off. And yet, when a tank was unexpectedly low on fuel, they pumped even more fuel into the empty tank and watched that disappear too. And then they said "Oops! We ran out of fuel!" If there was ever a case of human error, this was it.
It's worrying, because although there is a place for checklists and standard operating procedures, you also have to think. You can't check your brain at the door and leave it behind.
Offline SkyMaster
« Reply #23 on: August 11, 2020, 03:31:45 am »
There was also Air Transat Flight 236 that glided on a long distance before successfully landing (okay, it was a hard landing).
But these all-engine-out landing are only successful in day VFR condition. At night or in IFR condition, gliding to a successful landing would required a tremendous amount of luck.
Offline SkyMaster
« Reply #24 on: August 11, 2020, 03:56:49 am »
The Air Transat Flight 236 crew were busy handling a low oil temperature indication when they observed that an automatic fuel transfer started sooner than expected. From that point the captain was trusting less and less the avionics of his plane. Also, the crew were in contact with the maintenance person from the airline and the crew followed the maintenance person instructions. Following the investigation, Airbus revised the A330 flight manual in regard to suspected fuel leak.
Also, it is always easy to judge any crew decision, after all the facts are available and weeks or months are spent reviewing the event.
The Accident Report, from the Government of Portugal, is available. It is only 103 pages long and easy to read.
