Currently I have most of my bench and lighting running off one 15A power point.
The bench is wired with multiple outlets, has its own RCD (Residual Current Device) that ends with a 15A plug into said power point. the bench runs most of the auxiliary lighting (flouros, LED task lights and a few CFL lamps) as well as the test gear, power supplies, etc.
I was wondering how others manage their power up/ power down routine? Leave most stuff active and just flip the main switch or do you religiously go around and turn each item on/off? Let it all run 24/7?
I mostly do the master switch flip after powering down things like the laptop, etc that I know won't be happy. I also physically remove the 15A plug if summer storms are around as I've experienced one too many lightning problems over the years!
