Author Topic: Baby AT motherboard question  (Read 1034 times)
Offline Ampera
    • Ampera's Forums
« on: October 21, 2016, 10:59:08 pm »
Is it possible to mount a Baby AT motherboard in a specifically ATX case? I am aware the general shape is the same, but do the screw positions match up whatsoever?
Professional complainer-in-chief criticizing other people's code
Programmer and bumbling Unix fool
Op @ EEVBlog IRC: irc.austnet.irc #eevblog
Offline ebclr
Offline MK14
Re: Baby AT motherboard question
« Reply #2 on: October 22, 2016, 02:16:55 am »
Yes, they usually do line up. You will obviously have some empty screw positions, in the case.
Remember to always use standoffs, unless the case is specially designed to not need them. Otherwise you can short circuit your motherboard, against the metal of the case.
« Last Edit: October 22, 2016, 02:18:47 am by MK14 »
