Ohhh why didn't this forum, subject topic and cheap digital camera's exist 20 years ago. I would have supplied my home made works of art... 200 watt stereo amp in a box, 50 watt amp on a plank of wood, 3d glasses, power supplies, 3d glasses, stationary bike generator, and the list goes on. But, one photo I've kept, only around a few years old, is a natural gas hot water tank, where the natural gas was disconnected, so, I used a 120v plug in fan heater feeding the base to make hot water and it worked for a year straight making enough hot water for showers and doing dishes for 2 people during the summer, 1 or 2 people being conservative in the winter, take a look: (The heater was running 24/7 on it's low/half power mode) And yes, I'm crazy! (There was NO natural gas service to the house!, nothing in the pipes, I'm not that dumb...) Yes, that tinfoil is multiple layers thick to the point that you might be able to call it duct grade & after 1.5year of use, once dismantling, there was a brown darkened spot on the lower right of the heater's heating element.
Through those 2 previous winters, I saved around 800$ total since natural gas here in Quebec now costs twice as much as heating with just normal baseboard heaters, not to mention if you have a heat-pump for the rest of the house...
